Gabriel Sá Pinto
Hi there, I'm working on an EMC Control Plan for a product in my company and I'm trying to simplify all the testing processes as we're doing them in house.
So there's one EMC that states the following:
"Secondary power supplies generated by the equipment’s internal DC/DC converter shall respect an isolation of:
Resistance > 1 M Ohm (see note 1)
• Capacitance < 5 nF (see note 2 & note 3)
between the following interfaces:
• Prim. power hot line/pin and Sec. power hot lines/pins
• Prim. power return line/pin and Sec. power return line/pin
• Prim. power hot line/pin and Sec. power return line/pin
• Prim. power return line/pin and Sec. power hot line/pin
Note 1) - The resistance measurement shall be done using an Ohm meter. The measurement shall be done for both polarities of the applied ohmmeter. During these measurements, the unit shall be disconnected from power supplies and powered OFF.
Note 2) - The capacitance measurement is global and shall be done with the test frequency <10 kHz (usually 1 kHz) and according to the procedure described hereafter. The verification might be needed before the DC/DC converter is implemented in the unit’s chassis.
Note 3) Isolation procedure to measure the DC/DC isolation:
STEP 1:
- Connect all primary power lines together and then to the ground
- Connect all secondary power lines together and then to a capacitor meter with respect to the gnd (frequency < 10kHz) then Cisolation + Csecondary_to_chassis is obtained.
STEP 2:
- Disconnect primary lines bundle from ground and inject 1Vpp voltage on this primary power lines bundle with respect to the gnd (keep preferably the same frequency)
- Perform a voltage measurement on the secondary power lines bundle with respect to the gnd. The output/input voltage ratio corresponds to the bridge attenuation Cisolation / (Cisolation + Csecondary_to_chassis)
- Multiply the measured capacitor value by the previous voltage ratio and Cisolation is obtained."
Basically the measurement of the capacitance is made in several steps and through calculations, is there any way the measurement of the isolation capacity between the primary and secondary power lines (and secondary or primary to chassis for that matter) can be done directly with a suited precision capacitance meter?
I'm having trouble finding suitable information online for this case.
Thanks in advance for your help.
Gabriel
STEP 1:
STEP 2:
Gabriel
