christinescoms
I used L293D to run Stepper motor and i did it with Bipolar Stepper Motor successfully... Then i came to know that is Dual H-Bridge Ic that can run DC motor in both directions... then i connected as like the diagram... logic input of 5V and motor supply of 12V with 7805 and 7812 regualtor respectively from 12V 5Ah battery... but the problem is the IC heating very hot within secods... I am using 12v 300mA DC Geadred Motor... but L293D can drive upto 600mA per channel and peak of 1.2A... but dont know what is the mistak i did... pls help me with this.. and also the motor runs only on Low input not on high and even when enable pin is not High... pls check my diagram and make me where i made mistake...
150RPM 12V DC motors with Gearbox
6mm shaft diameter with internal hole
125gm weight
Same size motor available in various rpm
2kgcm torque
No-load current = 60 mA(Max), Load current = 300 mA(Max
125gm weight
2kgcm torque
