surface mounting DIP/DIL package?
dalmation
Does anyone have a tried and tested technique for surface mounting DIP/DIL packaged IC's?
I was gonna bend the pins out or under and give it a try. I might even bend then over and mount the chip upside down for one particular circuit where the pinout would be much better 'mirror image'. I know it sounds daft, but I have my reasons.
Anyone had any experience of this madness?
Thanks in advance.
-Dalmation.
Thanks in advance.
-Dalmation.
I have used DIP ic's with legs bent at right angles, works fine.
You can crop the pins/legs to shorten them if space is tight.
Never used the method for upside/down mounting.
CAUTION: the legs will break off, if repeatedly bent to and fro.
IC socket: Through hole to SMT.
I'll experiment tonight (with the cheapest IC's I can find).
I'll also try converting some of my sockets into SMD.
The upside down thing might be a bit ambitious, but I'm gonna try it anyway.
I'll post pictures if I get good results.
-DAlmation.
I've bent the legs under the DIP package with success. You need to trim the leads back a bit so they don't touch any traces running under the IC.
It worked good for me.
I had a wee go there.
Bent the bottom half of the legs outwards (90 degrees), then trimmed them back with snips (using a credit card as a spacer to leave a 1mm 'foot'.
Looks just like a SOIC chip now. It makes the chip footprint quite wide, so I'll try bending under the chip as well.
-Dalmation.
