How to make flip-flop (frequency-divider) with schmitt inverter?
Hi
Ideally, i'm looking for a simple frequency divider that i can feed a square wave, using only schmitt inverters or schmitt NAND (just one if possible). Should work over a wide input-frequency range.
The posts below provide a schematic for a so-called "flip-flop" (which i think is really a toggle, not a flip-flop) using two schmitt inverters.
https://www.electro-tech-online.com/threads/electronic-switch.26093/#post-181844
http://forums.adafruit.com/viewtopic.php?f=8&t=36970&p=607457#p607457
http://www.learningaboutelectronics.com/Articles/Touch-on-off-circuit-with-a-7414-inverter.php
The circuit is based on a switch, not a clock, so would not work as-is for my need. But, maybe someone can see a way to make this work as a divider with a clock-input instead of a switch? Or, some alternate flip-flop circuit using schmitts?
I wired up the above circuit in falstad
http://tinyurl.com/ya8cz2nm
Issues:
  • Seems highly sensitive to input on-time.
  • Getting strange oscillations.
Pressing the switch manually, i sort of get a toggle, sometimes. Seems to depend on how long i hold the switch, and maybe how long i wait between presses, and whether i'm going from low to high or high to low. Also, i seem to get a very high frequency oscillation while holding the switch. Am i doing something wrong?
Any ideas for a true flip-flop divider based on Schmitts?
thx
It's difficult to use such a circuit over a wide frequency range since it depends upon RC delays for proper operation..
Much easier to just us a D-flipflop with the D input connected to the /Q output.
no easy, wide-frequency way
you never know until you occasionally somewhere run to it - some setup of T-flop might just do what you need
by Google iS . . . the good question here is where to get the BUTTON with the right "Moment" . . . the 100k somewhat incorporates here . . . donno ← an idea level design (in latch setup the button would be the 3-rd transistor) while the Bjt v. has only 2
Here is the simplest, "real", divide-by-2 circuit made from gates. It is properly edge-triggered, and changes on rising-edges. It can be built from almost any logic family, provided that the max frequency is consistent with the gate delays.
  • Draft49.asc
