Help with a timer 555
Jrohg
hello i would like some help with a circuit i'm trying to make, here is what i want the circuit to do.
The Input 12v
And i want the Out put 12v
Once power is applied to a 555 timer, I want an 12vLED to be on for 5 seconds, and cut off (NO FLASHING). Once power is taken off, and applied again, this "system" will restart.
Thanks i really appreciate any help
Circuit #1. Replace the two diodes and relay with an LED and resistor.
ak
Here's the LTspice simulation of the circuit AK posted with RC values to get a 5s pulse, and the suggested output modification:
First thanks for helping. I tried the circuits but they didn't do what i need, i put power turns led on but it doesn't turn off the led because i don't take out the power.
That's my problem that the circuit has to turn off the led Without taking the power from the trigger
The circuit does what is described in post #1. Try to explain again the sequence of events that you need. List them as a number of steps in a sequence.
ak
Then it would appear that there's an error in the circuit you built.
The simulation shows the output turning off after 5 seconds with the power continuously applied.
