Andrew Leigh
my friend was throwing away an older model Coleman Thermoelectric Cooler which he said did not work very well. I took it from him to see if I could fix it for camping so here goes with a couple of questions;
1) Firstly, the contact surface on the plug is corroded to to point that only after vigorous jiggling did the fan come on. I assume this poor contact forms a high resistance joint and impedes current flow?
2) In his attempt to fix the cooler he has used copious quatities of the white thermal transfer paste, can one use too much paste?
3) The peltier device is about 40mm x 40mm seems very small for a 32 quart fridge. Can one tell the "cooling effect" from the amount of current it draws?
4) Have peltiers become more efficient or are they limited by their chemistry?
5) Years ago I got a sample of a grey thermally conductive flexible sheet material made by Courtaulds Aerospace. Intended use was to replace the paste as it was dry and easy to work with, spec's claimed it was more efficient but is was way more expensive. Anyone familiar with the material?
Cheers
Andrew
Cheers
Andrew
