paralise without opening
georgetwo
Hi everyone !
This sounds bad but I need it
I want to buid a circuit that will produce enough voltage to paralise or kill a circuit (stop it from woking), if possible without opening the case.
just want to do it.
**broken link removed****broken link removed**
Hi everyone !
just want to do it.
You're right, that certainly sounds bad. You're essentially asking us to help you vandalise someone's property?
Use a taser or stun gun.
Would that actually work or is it a joke? :D granted I know little about EMP, but my understanding is that a powerful magnetic field is created, and combined with the relative motion of the coil creating the field and the wire you want to affect, a current is induced in the wire... but to produce a magnetic field of sufficient magnitude to produce a current capable of damaging most components it would require a great deal of power in the coil, would it not? I don't think high voltage with low current would cut it...
I could be wrong, feel free to correct me. Interesting topic, but hopefully the OP won't be stupid enough to try building one and vandalising someone's property with it...
A taser works on you doesn't it? And you are far more immune to EMP and ESD than a circuit is.
I just use the remote, its the red button at the top. Elvis only didn't do it this way because TV remotes didn't exist yet, and he had a gun right there.
Tasers work on me by directly passing a current through me due to high voltage. We're talking about using a taser to induce a current in a circuit which is separated from the taser circuit by an insulative casing, i.e. producing an EMP to overload the circuit... I think? Maybe we moved on since then. Obviously if a taser is put across the terminals and the circuit is completed, that would totally fry most circuits; I'm certainly not debating that.
By the way, dumb question perhaps but what is ESD an acronym for? Electro-static discharge perhaps?
to be good in any thing u need to kow the good the bad and the ugly.
no suggestions ?
I believe a suggestion was made of using a taser. If you want to do it without opening the case, I believe the only real solution is using an EMP generator, which isn't really an option given the power requirements. Or hey, start a fire if you're really that intent on damaging whatever it is. I accept no responsibility for your illegal actions :rolleyes:
That's for me to know and for you to find out :D
I'll go with electro-static discharge. I'm certainly more protected against static than most circuits :D but you see what I meant, right? Tasing a circuit may well trash it, but it's not going to be much help inside an insulative case. Need a powerful electrical field to induce a current in the circuit for that, i.e. an EMP generator. Not going to happen using a taser :D not sure of the calculations involved, been a while since I did physics involving induction due to electromagnets (and I did it at a basic level even then) but I'm thinking power is required, not just voltage.
EMP has similar problem when in a metal case. So just use bullets...or carbon dust or a good ol' sledge hammer.
A taser produces a high enough voltage to arc through the gaps in most insulated cases.
I remember playing around with a piezo igniter and accidentally zapping my alarm clock radio - it was ruined.
A piezo igniter only produces a static shock a tazer produces a severe shock.
Perhaps I was a bit fixed on the EMP idea. Mainly because it's far more interesting than using a taser to jump through small holes in an insulated case :p
Either way, I don't think it's a good idea to so blatantly help the OP commit a crime so I don't think I'll be making any more comments on this >_>
This sort of topic should be against the forum rules or we should at least be able to flame the original poster to some extent.:D
I guess we'll just have to settle for sarcastic suggestions and evil stares in his direction. :D I was tempted to draw up a circuit consisting of a battery connected to a lovely artistic rendering of a stick of dynamite but I'm too busy to shoot him down *that* badly right now :p
