Model of LM331 for LTSpice
alec_t
Most Helpful Member
Stimulated/provoked by other threads related to this topic I have come up with the attached model for the LM331/231 in a test rig.
It's just an asc schematic, so cut and paste the bits within the dotted rectangle as required.
No doubt someone out there will be able to convert it to to a general-purpose sub-circuit which LTS recognises. I tried but failed, and would be interested to know how it's done.
Edit: I've fallen into a previous trap! The 311 in the title should be 331.
alec,
Runs OK, I will keep it on file.
You could make a hierarchical circuit of the asc circuit.
Interesting to see if the OP from the V2F thread is able to make use of it.
Thanks for correcting the title, Eric. All those other posts about 311 left me befuddled!
That's where I tried but failed. I retained just the bits in the rectangle and saved as an asc file, copied that to various LTS folders, then created a symbol. Tried adding the symbol, plus various .lib, .inc directives, to a new schematic. No joy. Error message about unknown subcircuit when the sim tries to run. Didn't know where to go from there. LTS Help says use it as a subcircuit. But how?
alec,
I have created a few hierarchical circuits OK, I will look thru yours, give a try.
EDIT:
This is a hierarchical circuit for a 4060, it may help you to follow the sequence
Note: you dont use an include
In your circuits keep the names the same and in the same folder, for starters.
I use the m1 as part of the name, to identify my circuits
alec,
LM331m1 zipped.
Place the LM331m1.asy file in the Misc folder so that you can use the symbol.
Unzip and for a test keep in same folder, its not very tidy, but it works. Use the LM331_testm1.asc to run
You could smarten it up if required.:rolleyes:
  • LM331m1.zip
    LM331m1.zip
Thanks Eric. I'll give it a bash.
I did as instructed.
It looks as though the main test asc file, the subcircuit asc file and the asy file all have to be in the same folder to get things to work. It wouldn't work when trying to run a draft schematic (in the LTSpiceIV folder), with the asy file and the subcircuit asc file both in Misc and both in .sym.
That's a shame. I was hoping to be able to use the subcircuit in the same way as LT uses its .sub files, with the subcircuit in the LT /lib/sub (or subordinate) folder and the asy file in the /lib/sym (or subordinate) folder.
It would be nice if LT could provide an enhanced folder structure with, say, an 'AddOns' handler, and an enhanced folder-search engine which looked in all folders from the LT root down, to make it easier to bolt on third-party models etc. (I know, I shouldn't look a gift horse in the mouth).
Do you know if synchronising (updating) the LT program wipes out any user additions to the LT-provided folders?
BTW, I assume the LT .sub files are encoded differently from user subcircuit files in some way to make them proprietary?
Mine runs OK, with the*.asy file in lib\Sub\Misc folder. C:\Program Files\LTC\LTspiceIV\lib\sym\Misc
I can use F2 , look in the Misc folder and select LM331m1.asy
You should keep the 'hier model' in the same folder as the LM331_test1.asc file.
Do not place the 'hier model in the sym folder.
I use also a second 'misc2' for trial work on models
I have upgraded about every 45 days from LTS, never over written of my work.
I do keep a full working back up on the D:\drive for LTS, just in case of some failure.
I will look at some options for making in more 'friendly'
I have made a neater version of the model, will post later.
alec,
This a neater symbol, also added pin numbers
Change the file extension from txt to asy
  • LM331m1.txt
    LM331m1.txt
alec,
LM331m1 zipped.
Hello Everyone. Thanks for the LTSpice model. I have one doubt though, Why the output voltage is limited to 30-32mV range? In the datasheet it is mentioned current output is some 120uA. But here it is not the case. Thanks
Hello,
In LM331_testm1.asc is a liitle bug. Pin of R6 connected to Vs should be connected to Vsupply. You will achieve impulses 0-10V.
I figured this 3rd party model was worth experimenting on a V-F configuration of mine, after patching this bug.
The attached schematic functions in the *real* world, but fails to simulate!
This is my initial attempt using SPICE and would appreciate any help getting simulation to function, as well.
fritual
fritual
You didn't provide the model and symbol. I have one I can provide.
Can you post a snapshot of the schematic?
eTech,
The symbol I used can be found in post #9 of this thread.
As for the hierarchical circuit, goto post #5 and put it in the same folder as my schematic in post #12.
The attached spec sheet circuit should match LM331 TestRig.asc in post #1.
HTH
fritual
eTech,
HTH
fritual
What is the measured V-to-F conversion values of your tested circuit?
2v FS in = ? Hz FS out
fritual
I seriously doubt the TestRig.asc will match the entire spec.
Can you provide specifics on which params in the specs your interested in?
Attached schematic shows conversion factor formula.
e.g., 1 v in == 20,574 hz out, max.
fritual
Current source, pin #1 that's fed back to pin #6.
The other concern is that the LTspice resistor's 'can' be polarized.
fritual
