Hero999 said:It's highly unlikely you can buy 12V motors this powerful use a higher voltage. A car starter motor might do but I don't know if they're powerful enough,
Nigel Goodwin said:Don't start him off with the car starter motors again! - they are absolutely useless devices (except for starting a car!).
I know this, I should've mentioned them too. I have a list of suppliers but it's at work. I've found a 24V 700W motor from Bosh for a work project and it was rater from -40 to 80 degrees C. However you really should consider using a higher volage at this power level, I'd use >36V.Nigel Goodwin said:Bosch make plenty of suitable motors, check the Robot Wars sites - it's the sort of things they use! - they also usually over run them to greatly increase their power.
Hero999 said:People have used them to power robots before and they've been quite good.
To many, this seems like an easily available motor. But in fact they are not good motors for conventional uses and we really cannot advise their use under any circumstances.
