Delay timer circuit conundrum
Ferdmonster
Being a rank amateur, customizing an off the shelf delay timer relay circuit is perplexing. It seems each circuit I purchase that is programmable has multiple programs, none of which meet my needs. My needs are:
Switch closes and stays closed
Timer starts counting down from 1 hour
If time goes to zero, relay closes
If switch opens before 1 hour, timer resets
I think that's all I need the circuit to do to start with. Eventually I would like to add the ability to send a text message if relay closes after 1 hour.
Right now I'm trying to learn to program Arduino but it doesn't seem my specs can be met by that system, at least so far in my study. Am I heading toward a dead end?
alec_t
Most Helpful Member
Welcome to ETO!
Does this help?
You could use an Arduino to create a required delay, then an I/O pin could switch a power transistor and hence a relay or other load.
Ferdmonster
Yes it sure helped me understand timed delayed relay functions. Thank you. It's just that I don't know where to study programming of these circuits that will meet my criteria.
alec_t
Most Helpful Member
Study the Datasheets for particular time delay relays you have, or are considering obtaining. Manufacturers often publish Application Notes too.
EE World Online Articles
Loading
