Analogue Dub Siren
You have a row of contacts on your Mickey Mouse breadboard shorting the gain pot:
No, it only looks that way on the picture (above, you cant see the pins). The pins on my "mickey mouse breadboard" are at separate rows, on pin is bent and placed alone in its own row. I can take a picture later to show you if you want.
Thanks anyway!
(Should have rotate it 90 degrees instead of bending the pin)
Is it wrong connected like its shown in the picture?
It is not a problem Rorut- you are the one doing the work and have the patience.
My post was not clear the resistor should have been 470 Ohms.
Otherwise all is correct and the opamps are not oscillating.
Can you try again with 470 Ohms and if the reading on your meter is still essentially zero volts, the opamps are not oscillating.
With the resistor, diode, capacitor and meter connected to one of the opamp outputs, can you then inject a signal into the inputs of the opamp and see if you get a DC reading on the multimeter which varies with the input signal amplitude.
spec
Hi again Rorut,
I see that you have only wired up opamp A of the LM358.
The other opamp, opamp B, needs to be put in a defined state.
Can you,
(1) Connect pin 7 to pin 6
(2) Connect pin 5 to 0V
The color bands on the blue resistors look odd on my laptop. Are the resistors actually 220K Ohms?
spec
I will try this after work later today
I am suspicious of the 4.7uF capacitor. It almost seems as though the 4.7K capacitor is not connected or open circuit.
Can you check connections and replace the 4.7K capacitor.
spec
Im using a 33uF. Negative on cap is connected to ground.
Thanks a lot for all help, hope I will come to a conclusion soon !
Thanks anyway!
Damn - I hoped AG had found the problem.:(
spec
Unbelievable. A sneaky pin of the pot snuck under the pot to a different row. Maybe the pot has a very low resistance?
Hi again,
Some more tests.
470ohm to anod on diode, cathode to 100nF (Film) capacitor, capacitor to ground and other end of 470 to pin 1 gives now 5.8v across the 100nF capacitor when pin 6 and 7 is connected and pin 5 to ground.
Connecting the siren with above setup gives 8.7v on multimeter.
Resistors are measured and gives correct values.
Is it oscillating now? And is that why the gain pot is not working? What is happening when the circuit oscillate? :)
Hi again,
Some more tests.
Hi Rorrut,
Yes, all things being equal, that is a clear sign that the A opamp is oscillating.
If this is true it will explain the problem including the odd audio sound.
I will have a think about the best next move.
In the meantime, can you:
(1) remove all inputs and outputs
(2) connect the high frequency detector to the output of opamp A.
(3) Check that there is a reading on the voltmeter.
(4) Without shorting anything, put your finger on various points on the circuit and see if the reading drops to 0V
spec
Great to hear :)
Yes I get 0v in the position where the two 220k meet with pin3 and film capacitor.
Video:
Great to hear :)
Video:
Morning Rorut,
From your video it appears that the opamp is oscillating (5V approx on the HF detector) but when you touch the junction of the two 220K resistors, the HF detector shows OV.
Once again that is a classic sign of oscillations.
Can you change both 220K resistors to 22K and see if the oscillation persists.
If that does not work, still keep the 22K resistors but also fit a 100pF capacitor between the non-inverting input and 0V.
If that does not work connect a 100pF capacitor between the two inputs of opamp A.
spec
spec
Hi again Rorut,
Would you like to try this:
(1) remove the 100K gain potentiometer and all associated wiring.
(2) fit a 22K resistor in place of the 100K potentiometer, but make the leads on the 22K resistor short and fit the 22K resistor as close to opamp A pins as possible. Especially keep the wires to opamp A inverting input short and compact.
Incidentally, the voltage gain of your amplifier is 1 + R2/R1 where R1 is the 1K resistor and R2 is the value that the 100K potentiometer is set to.
So with the 22K resistor fitted in place of the 100K potentiometer the voltage gain of opamp A will be 23.
spec
Morning Rorut,
spec
spec
Hi Spec,
only had 20K resistors and 1nF capacitors.
Same result with thoose as before.:(
Hi again Rorut,
spec
I removed pot and wiring and placed a 20K from pin 1 to 1Uf and now multimeter reads 10.5v and does not go down to 0v like before when I touch the 20K (or 220K) resistors connected. Is this a good sign? :)
Hi Rorut,
No, not a good sign: it seems to indicate that opamp A is oscillating in a big way now.
This is unbelievable because we are only messing with a simple amplifier with a voltage gain of 23.
And the LM358 is known to be an easy-to-use opamp.
This is a long shot, but where did you get the LM358s from?
spec
Hi Rorut,
spec
Yes unbelievable, but I think Im learning som stuff on the way and that is pushing me forward. I bought it here:
https://www.electrokit.com/en/lm358an.43035
Well known supplyer in Sweden.
Thank you!
Thank you!
That looks like a good source.
This is just a thought, but I have known faulty batches of components, but I do not think that is the problem.
Do you have two power supplies to give plus and minus 12V or 9V say (the supplies do not have to be the same)? a couple of batteries would do.
I am still suspicious of the 3.3uF capacitor that connects to the 1K resistor. Can you try replacing that capacitor for a non-electrolytic type, as big a value as you have- ceramic will do.
spec
Morning :)
Yes I have a couple of 12v laptop psus I can use. Should I take away the devider and give the lm358 12 directly . 12v and -12v?
I will look after my biggest film/ceramic capacitor I can find and take a better picture.
Again, big thanks!
Morning Rorut,
I will post a new LM358 amplifier schematic to act as a reference.
spec
