It is well glued unfortunately , and i notice that unlike linear transformers , these use a special type of metal .
You can also heat the transformer in a toaster oven. This way the heat is more even and controlled.I have salvaged these and reused them.
If you heat the glued areas with a soldering iron and a hot air tip for a gas solder iron you can usually get the glue to soften nd release, sometimes the inner core is glued which makes things tricky.
If you break the core you can superglue it, it doesnt seem to change the properties much.
As mentioned if you heat the core too much and go past the curie point its properties will be ruined, but thats hard to do, the coil former would certainly melt first.
Keep the tape and reuse it, or salvage another trans.
I've replaced many chopper transformers over the years - but it is fairly rare, and it's only certain specific models where they do fail. It's VERY, VERY rare to get a 'one off' failure - if you come across a transformer failure in a particular unit, it's most likely you're going to get lot's of those units in with the same fault.
Faults I've seen include O/C windings, shorted turns, and even shorts from primary to secondary
From what I can remember we used to stock 3 or 4 different chopper transformers?, so that was the sort of number of common model failures we saw here in the UK.
In deed , i rarely find bad transformers on the units i repair be it on welders , PSUs, usually its either shorted power transistors , PWM ic or startup resistors .
Good call BGAmodz
Rep for you. Cause I can and you learned something.
Regards,
tvtech
