555 trigger delay help
Thanks Eric
I think I got it . . . ,
Make it Circuit-1 (old 555 circuit) and Circuit-2 (new 555 circuit)
Build circuit-2 similar to the one posted (circuit-1), omitting Q1, D1, RL1.
Adjust RV1, R3 and C1 for desired time needed in ms.
Connect J1(reset terminals) of Circuit-1 to (omitted RL1) of Circuit-2.
Use same trigger from the IR-beams to trigger both circuits same time,
Circuit-2 will keep the reset pin of Circuit-1 to ground for X-time ms,
See I do need a memory replacement does take time some times to snap into place.
Will try it this way.
Theunis
Thats good!, two heads are always better than one.:)
See how you go, come back if need be.:)
Hi guys
Need to know what to do to modify a simple 555 monostable circuit, when a trigger pulse is kept closed/on that the circuit will still time out, and not stay triggered as long as the trigger pulse is kept close.
Theunis
Hi guys
Theunis
Hi,:)
Is this the delay 555.?
If yes, then connect the trigger via 2n2, have a 10K pull up from the TRIG input.
So the trig is capacitive coupling, not direct.
Hi Eric,
Yes- for the delay circuit, (need a quick diagram/schematic please. (if possible))
(Pity only have weekends and holiday to actually work on this !)
Thanks again
Theunis
Hi Eric,
Thanks again
Theunis
hi Theunis,
Since the earlier posts I did some simulation circuits.
Its has to be triggered for a minimum period or number of short periods.
Look at this example.
Eric
Thanks, again much more than I expected.
Please confirm components:
Q2 = BC557
V1= ?
V3= ?
I take it Pin3 of U1 goes to Pin2 of U2.
Can you give me a short explanation of the output ?
Again KISS please.
Thanks for the help.
Theunis
Eric
Q2 = BC557
V1= ?
V3= ?
Again KISS please.
Theunis
Q2=BC557
V1 represents your existing 12V supply.
V3 is there for the simulation only, it closes the MWSWitch contacts.
U1/3 >>> U2/2 [trig].
BTW: the U2/3 goes to your relay transistor driver as previously.
I'll post a plot of the waveforms, with an explanation.
The BLUE trace represents the relay contact closures of the detector relay.
I have shown 3 short pulses, that could be caused by leaves or birds breaking the beam.
You can see, during each pulse the timing capacitor of 555/1 charges a little, on the 3rd pulse the cap voltage is sufficient to allow 555/1 to time out.
The low going output pulse of 555/1 triggers the 555/2 input, as the 555/2 is configured as a mono its output will go high for the time of Res/Cap values.
In the case where the beam is broken for a longer period, the 555/1 cap will charge faster and trigger the 555/2.
When the 555/2 is timing it discharges the timing cap of 555/1, getting ready for any further beam breaks.
If the 555/1 see's say, just one leaf, then the charge on the 555/1 timing cap will be slowly discharged by the resistor in parallel with transistor.
You may have to adjust the timing values on the 555/1 to suit the application.
Do you follow OK.?:)
EDIT:
added a second waveform, showing when detector relay is closed by intruder.
Longer closure time.
Eric
Again thanks a ton, it is clear enough for a rookie like me.
I understand the principle/concept of the circuit, it is brilliant.
To make 555/1 adjustable/more or less sensitive I can replace R3 with a pot?
Does it need to be TLC 555, ( I only have 1) with the component values you supplied or would other CMOS types do as well?, I noticed they (TLC series) do not trigger the timer when power is applied, like most of the others do.
Attached is a photo of the main board that I have already built with 5 x 555 timers as per attached circuit at post #9 of this thread. (I have omitted the leds + their res, the jumpers with additional caps and resistor for a wider timing from the posted circuit for simplicity)
The idea is to get
Timmer #1 will switch a buzzer for X sec.
Timmer #2 will switch on outside light at night for Y min, at the same time as #1.
Timmer #3 will switch on a siren when set, and will be used as a panic button connected to a wireless remote button.
Is it possible and how to incorporate your trigger circuit with this main board circuit.? As posted in #9.
Otherwise I can rebuild it on your design, it needs to be a stable/flawless system though.
People are voting here this week so not much will happen economically (business wise). Will then make a board and build your design.
Thanks for your time.
Theunis
Eric
I would connect a fixed 4K7 in series with say a 50K pot
In theory any CMOS version 555 should be OK.
Im not sure what #9 means.???
Its been run thru a number of different simulations.
Theunis
Its always necessary to prove any design simulation by constructing a working model [prototype].
As they say 'the proof of the pudding is in the eating, not in the simulation'.:)
The only changes to your original design is the 555/1 delayed triggering circuit.
Sorry I meant post #9
Looking at the circuit you posted, I would then only use U1, taking its output (pin3) to the trigger on my main board (J2) ? ? ? , (as posted in post #9.)
Which of the components can be omitted in your circuit if only U1 is used ?
(I just realize now you would probably have chosen a PIC with much less components to do the same thing ?)
Theunis
Theunis
I thought we were trying to modify a one off, existing detector/555 relay driver.??? from being triggered by a falling leaf.
The rightside 555 is your original circuit with a leftside 555 delayed trigger added.
I havn't shown the output relay thats all.
If for a new design I would have chosen a PIC.
Sorry (My bad, you lost me.)
Yes, we are still working on the falling leave delay trigger to a 555 circuit (existing), (would it matter if there are 5 x 555 in stead of 1x 555 using the same delayed trigger from the IR-beam.) ?
Take it then that S2 is the trigger in, coming from the IR-beam ?
Can you indicate the output relay as well, can help to get mind around it.
What software do you use to simulate the circuit ?
Theunis
Look at this edited dwg showing the existing relay and the S2 relay contact.
Sim is LTSpice.
The 5 * 555 trig should be OK.
Eric
Thanks makes more sense now ! ( Pictures makes more sense at my age, still trying to understand the theory)
Can I go-ahead and build this ?
Will give feedback in the week.
