variable shift registers
siri1234
hi everybody ...i m new to this forum...so i dont know if it is the right place to post my query..i have a project to complete..i need to design a variable shift register ...that shifts say 'i' bits if the input is 'i'...can anybody suggest any material or books or websites where i can find this kind topics????.....
any hints?????
ericgibbs
Most Helpful Member
any hints?????
hi,:)
One option would be to have a parallel load down counter driving a shift register.
Preload the counter, start a down clock to the counter, the clock also clocks the shift register, stops when the counter reaches zero.
Is this what you mean.?
ericgibbs
Most Helpful Member
oh...ok...i m trying it it out...thanks a ton:)
Lets know it goes.
If you want to shift a preloaded 'pattern' into the shift register, use a parallel to serial shift reg.
Roff
How about a serial in, parallel out SR with a multiplexer to select the "i"th output?
