No, you only need seven for every piece to be visible in the last square (the output location of the shift register) - because the first in there already at the end of the loading sequence.You need only 7 pushes to take the 8 pieces from the board?
ABCDEFGH
87654321
ABCDEFGH-ABCDEFGH
XXXXXXX8-7654321X
The seven is a fallacy. That is what I'm trying to explain.But actually you need only 7 not 8.
Exactly, in any practical application.If you want to remove all the 8 bits from the register;
then you should remove them from FF H also;
