Unicorn GLCD demo.
You must have changed some other part of the code as it works perfectly on mine. What happens if you call ClearScreen before printing the text?
what is your current code for:
void ClearScreen(void)
also pommie shouldnt this be more like:
void GLCD_Write_Data (unsigned char data){
	Wait_Not_Busy();
	GLCD_Data = [B]~(data)[/B];
	b_GLCD_RS=1;
	b_GLCD_RW=0;
	b_GLCD_E=1;
	Delay();
	b_GLCD_E=0;
unsigned char GLCD_Read_Data(void){
	Wait_Not_Busy();
	TRIS_Data=0xff;
	b_GLCD_RS=1;
	b_GLCD_RW=1;
	b_GLCD_E=1;
	Delay();
	W=[B]~(GLCD_Data)[/B];
	b_GLCD_E=0;
	TRIS_Data=0x00;
	return W;
Pommie it gives the same result.
ClearScreen when called actually turns the screen complete black. Is it possible that my screen is running in inverted mode already. When (in proteus) the screen is powered on, it gives black background.
AtomSoft: Its the same thing, gives the same result :) I tried what you said earlier before asking question here on forum ;)
Is this your GLCD clear screen?
void ClearScreen(void){
unsigned char i,j;
	b_GLCD_GCS1=1;
	b_GLCD_GCS2=1;
	for(i=0;i<8;i++){
		GLCD_Write_Cmd(0x40);	//y=0
		GLCD_Write_Cmd(0xb8+i);	//x=0
		for(j=0;j<0x40;j++)
			GLCD_Write_Data(0x00);
	SetPos(0,0);
If you are then try this:
glcd-jpg.35505
also revert all the data back to normal, meaning If you changed the read data and others put them back to normal.... the only thing that should be changed is:
	Wait_Not_Busy();
	[B]GLCD_Data =~data;[/B]
	b_GLCD_RS=1;
	b_GLCD_RW=0;
	b_GLCD_E=1;
	Delay();
	b_GLCD_E=0;
clipboard03-jpg.35506
had 10 min free so here it is: (Tried it on 18F4620 tho)
From design to creation:
glcd-jpg.35542
Thank you AtomSoft, its seems like you are an expert ;).
I am working on an image based display for Fan percentages
I have attached a small image (128 x 64) pixels which might give a little clearer idea.
Its kinda like volume bars going up and down according to input.
Will this be possible to make or are there some limitations that i might need to know prior to a result in vain. :D
ShoulD be simple to do.. i would suggest using the line command. mainly because images take up a lot of space... you can have 1 function draw the bars .
Is there any function to print numbers on the LCD?
I've just the one below, but doesn't work. It prints a junk of meaningless ASCII characters.
void glcd_Write8BitNumber(unsigned char num)
	unsigned char hundreds = 0, tens = 0;
	char szNum[4];
	if (num >= 200)
		hundreds += 2;
		num -= 200;
	else if (num >= 100)
		hundreds++;
		num -= 100;
	while (num >= 10)
		num -= 10;
		tens++;
	hundreds += 0x30;
	tens += 0x30;
	num += 0x30;
	szNum[0] = hundreds;
	szNum[1] = tens;
	szNum[2] = num;
	szNum[3] = 0;
	PutMessage((rom char*) szNum);
heh easy one now
sprintf like...
    contrast = 57;
    sprintf(tempStr, "Contrast: %d",contrast);
    // lcd code to place string on lcd here
^ Now it's worse. It clears out the screen when I try to print the string.
	while (1)
		glcd_ClearScreen();
		glcd_SetPosition(0, 0);
		ADCON0 |= 0x02;
		while(ADCON0 & 0x02);
		glcd_PutMessage((rom char*) "The temperature is: ");
		//glcd_Write8BitNumber(ADRESH);
		//glcd_Write8BitNumber(ADRESL);
		glcd_Write8BitNumber(20);
		Delay10KTCYx(0);
	char szNum[40];	// I think 40 is large enough
	sprintf(szNum, "%d", num);
	glcd_PutMessage((rom char*) szNum);
I see the string "The temperature is:" for half a second, then the screen is wiped out.
You can't use PutMessage to print a string that is in RAM as it expects a ROM pointer. What you need to do is,
unsigned char szNum[40],i;	// I think 40 is large enough
    for(i=0;szNum[i]!=0;i++)
        PutChar(szNum[i]);
But, I would make it print a signed integer,
void glcd_WriteInt(int num)
unsigned char szNum[7],i;       //can contain up to 6 characters with the sign
        PutChar(szNum[i]);
I have a little problem making the lines.
When i put code:
box(120,0,128,0);
box(120,7,128,7);
It only displays one line. The problem is that the offset of the two lines needs to be more than 8 pixels. Is there any option of drawing boxes smaller than 8 pixels?
For example, according to my understanding, the following command should make a four pixel thick box but it doesnt.
box(0,0,128,4);
