Twin Display Basic Counter
Emjack24
Hey all, so my friends and I play a card game with has In it life points.
We use dice atm to keep track but with 4-6 people on a large table it can be hard to see each others totals.
I was looking for help with a design. I'm somewhat practical, can solder.
In my mind I'm picturing a triangle prisim with a display on the outwards facing side so all can see the current life total
and on the inwards facing side a display so the player can see their own. An on/off switch and up and down buttons to increase or decrease the life totals. It would be very very rare it'd need to go over 100 so a 2 digit output would be fine.
I unfortunately have limited knowledge with electronic design. If anyone can help it'd be amazing. If it didn't use custom PCB or any PCB for that matter the better! As I don't have the gear, for that.
Cheers in advance.
Jack
The need to sum all the individual player tallies lends one to do it wirelessly.
Mesh network - https://randomnerdtutorials.com/esp-mesh-esp32-esp8266-painlessmesh/
Here is a possible module to handle the player side. But you would need to
do some programming.
That module can both handle the up/dwn off buttons as well as tally and display. In
addition send its total wirelessly to a central module for display total. I would think in
terms of one doing this type of display -
More programming. I would think in terms of using Tuniot to do the programming. Its block
programming. A example -
Regards, Dana.
Are you able to program and are you comfortable programming serial?
If you are able to then I suggest a TM1637 module on each side, This is a four digit display so could show the current player number and the total number. It's programmed serially and would need a separate clock line for each module but they could all share the same data line. Googling "TM1637 arduino" will get you lots of example code I.E. This. I would suggest an Arduino Nano as they are the same as a Uno but a smaller footprint.
It would probably need to be mains powered as all those LEDs will soon flatten batteries. A 9V 1A wall wart type supply should provide plenty of power or you could use a USB charger.
The push buttons should be simple enough, two per side is 8 (or 12) which can easily be read using 6 (or 7) pins.
