this is just for novelty value, something I had not seen such an extreme example of before.
My laser printer started acting up a few weeks ago, it gave an error when trying to use the second (add-on) paper tray. I did not have time to start digging it to the problem then so just removed the tray module; the printer just sits on top of it.
I noticed when I switched it back on that the PSU struggled to start up, so that seemed a likely culprit - the thing has been powered for around 10 - 12 years... It did work after a few minutes and has been OK since, though the print quality seemed to be a bit off.
Last weekend I stripped it down and found some caps in the PSU had started to visibly swell, so I got replacements for all the ones in the power (rather than control) sections.
Once they arrived and were fitted, the printer works fine again, including with the second tray.
I tested the old caps out of curiosity; some still read OK, some were obviously rather sick. The worst two were a couple of 2200uF 10V ones connected in parallel for the 5V output.
How on earth the thing was still managing to work at all is mindblowing, hence this post!
