Speedometer
All finished, heres the code;
Device 16F876
Declare XTAL 20
Config XT_OSC , WDT_OFF , PWRTE_ON , BODEN_OFF , LVP_OFF , CPD_OFF, CP_OFF , DEBUG_OFF
Declare LCD_TYPE 0
Declare LCD_DTPIN PORTB.4
Declare LCD_ENPIN PORTB.3
Declare LCD_RSPIN PORTB.2
Declare LCD_INTERFACE 4
Declare LCD_LINES 2
Dim KMH As Float
Dim Temp_Float As Float
Dim KMHT As DWord
Dim KMH_Last As DWord
Dim Result As Word
Dim Total As Float
Dim Last_Result As Float
Dim X As Byte
Symbol _1_Min = 1.243
Symbol _1_Max = 2.355
Symbol _2_Min = 2.356
Symbol _2_Max = 3.194
Symbol _3_Min = 3.195
Symbol _3_Max = 3.709
Symbol _4_Min = 3.710
Symbol _4_Max = 4.307
Symbol _5_Min = 4.308
Symbol _5_Max = 4.674
Symbol _6_Min = 4.675
Symbol _6_Max = 4.810
Symbol _N_Min = 4.811
Symbol _N_Max = 5.245
TRISC.0 = 1
DelayMS 1000
Cls
Print At 1,5, "KM/Hr"
KMHT = 0
TRISA.0 = 1
ADCON1 = %10000000 			' Set analogue input, Vref is Vdd
Start:
	Result = 0
	Total = 0
	X = 0
	Repeat
		  Result = ADIN 0
		  Result = Result * 2
		  Total = Total + Result
		  Inc X
	Until X = 15
	Total = Total / 15
	Total = Total * 5 / 1023
	Select Total
		   Case _1_Min To _1_Max
		   		Print At 2, 1, "1st Gear ", DEC3 Total, "V"
		   Case _2_Min To _2_Max
		   		Print At 2, 1, "2nd Gear ", DEC3 Total, "V"
		   Case _3_Min To _3_Max
		   		Print At 2, 1, "3rd Gear ", DEC3 Total, "V"
		   Case _4_Min To _4_Max
		   		Print At 2, 1, "4th Gear ", DEC3 Total, "V"
		   Case _5_Min To _5_Max
		   		Print At 2, 1, "5th Gear ", DEC3 Total, "V"
		   Case _6_Min To _6_Max
		   		Print At 2, 1, "6th Gear ", DEC3 Total, "V"
		   Case _N_Min To _N_Max
   		   		Print At 2, 1, "Neutral  ", DEC3 Total, "V"
		   Case Else
   		   		Print At 2, 1, "Unknown  ", DEC3 Total, "V"
	EndSelect
        KMHT = Counter PORTC.0, 250
	If KMHT = 0 Then Goto Display
	Temp_Float = KMHT
	Temp_Float = Temp_Float * 4 * 7.2
        KMH =  Temp_Float / 1000
	KMHT = KMH
Display:
	If KMH_Last <> KMHT Then
            Print At 1, 1, DEC3 KMHT
	    KMH_Last = KMHT
	EndIf
    GoTo Start
You can modify the Symbols Containing the Min and Max voltage values that are allowed for each gear.
The program can probably be tweaked - eg I left the volt display on there for debugging and you can remove it once you feel happy you know all of the volages are correct.
Watch the circuit in action here
The SIM appears laggy as there are 7 Signal gererators in use. It will be much faster in real time.
You might be asking why on earth I used a voltage divider in the circuit - its because in Neutral, the were voltages over 5V, and PIC's don’t like that!
So to keep everything to operating standards, the voltage divider is just halving the sample voltage; eg, 5.5V from the gear selector output will now be sampled as 2.25V by the PIC. The program scales it back up mathematically :)
Device 16F876
Declare XTAL 20
Declare LCD_TYPE 0
Declare LCD_LINES 2
Dim KMH As Float
Dim KMHT As DWord
Dim Result As Word
Dim Total As Float
Dim X As Byte
TRISC.0 = 1
DelayMS 1000
Cls
KMHT = 0
TRISA.0 = 1
Start:
	Result = 0
	Total = 0
	X = 0
	Repeat
		  Result = ADIN 0
		  Result = Result * 2
		  Inc X
	Until X = 15
	Total = Total / 15
	Select Total
		   Case Else
	EndSelect
	Temp_Float = KMHT
	KMHT = KMH
Display:
	    KMH_Last = KMHT
	EndIf
    GoTo Start
Looks great for me, I'll try to understand what you did and run it on the bench and then on the bike. But I can tell you that for some reason that I don't know yet the speedo when I install on the bike have a strange behavior, I mean, the speed readings are not accurated, but it's on the bench when I simulate the speed with signal generator, tomorrow if my wife permit, I'll troubleshoot my bike's voltage regulator and generator.
I apreciate you help indeed and thank you very much
ps: If you have any more ideas please let me know.
OK I understand and I have it in my circuit, thank you.
Does the gear voltage vary with engine RPM. If so, the voltage may be relative to the battery voltage and you may be able to fix it by setting the ADC reference voltage to a division of the battery voltage.
BTW, have you changed to a schmitt trigger input and if you have, did it work?
Unfortunately not and I have changed de input port to RC7 and still the same. I think I have some kind of noise that come from the generator because when the engine is not runnig or the circuit is on the bench it works ok. I didn't have time to try the gramo routine yet and to troubleshoot the generator.
I will post the news later just for information. Thank you very much.
FYI attached is the circuit I'm using.
I increased the value of C5 and C7 to try to filter any noise (didn't work).
I've placed a 10k resistor (pull-down) on PORTC7 then I removed because it killed the signal to the original bike's speedometer.
I think your problem is in the ground - what ground did you use when you measured the voltages? I think you should use the black/white wire on the gear position switch connector, not just any ground on the bike.
Attached is a picture of how I think the Suzuki gear position switch is wired.
D.
Device 16F876
Declare XTAL 20
Declare LCD_TYPE 0
Declare LCD_LINES 2
Dim KMH As Float
Dim KMHT As DWord
Dim Result As Word
Dim Total As Float
Dim X As Byte
TRISC.0 = 1
DelayMS 1000
Cls
KMHT = 0
TRISA.0 = 1
Start:
	Result = 0
	Total = 0
	X = 0
	Repeat
		  Result = ADIN 0
		  Result = Result * 2
		  Inc X
	Until X = 15
	Total = Total / 15
	Select Total
		   Case Else
	EndSelect
	Temp_Float = KMHT
	KMHT = KMH
Display:
	    KMH_Last = KMHT
	EndIf
    GoTo Start
How did you find the constants assigned below?
D.
I'm taking the ground from somewhere in the instrument cluster.
I'll try to change the ground...
See attached the bike's diagram
Thank you
Heres your real life data:
1st gear = 1.243v to 2.586v
2nd gear = 2.124v to 3.210v
3rd gear = 3.178v to 3.486v
4th gear = 3.633v to 4.400v
5th gear = 4.215v to 4.887v
6th gear = 4.461v to 4.942v
Neutral = 4.678v to 5.245v
As they overlap, I had to find the "Middle" between each set. Take the First Gear for example:
1st 1.243v - 2.586v
2nd 2.124v - 3.210v
Now the "Overlap" from 1st too 2nd is 2.586 minus 2.124 = 0.462V
As I now know how much they overlap by, I simply divide this by 2 so I can split the overlap evenly 0.462 / 2 = 0.231
And now add that value to the lower voltage 2.124 + 0.231 = 2.355
There you have it - the "Middle" point for the overlap between gears :)
I did however modify the gap between 2nd to 1st as it was not the same (too small) and figured it was a miss read
1st 1.243v - 2.586v
2nd 2.124v - 3.210v
Allright, thank you
gramo said:
I said i modified 2nd to 1st, I meant 2nd to 3rd
Ok I understood, but one more question my friend, in your simulation you told the voltages (sine wave) for each gear are 10khz from min to max, Why? and don't you think it's better to put a little delay between the readings for speed because as it's a digital reading any little change on the speed will be displayed on LCD but not on the original speedometer?
Rgds
Rgds
I chose a frequency of 10K as a random "out there" number, to simulate noise from other devices on motorbikes circuits, it could be much less that.
There is no delay in the routine - as I 'average' multiple samples with the following code
	Result = 0
	Total = 0
	X = 0
	Repeat
		  Result = ADIN 0
		  Result = Result * 2
		  Inc X
	Until X = 15
	Total = Total / 15
This way, I can average out and slew noise from my final result. Lets say for example my 15 readings were the following (The bike is in 1st gear):
1.25, 1.0, 2.3, 2.7, 1.1, 1.5, 1.7, 1.77, 1.79, 1.2, 2.4, 2.45, 1.5, 1.6, 2.8
The samples in bold were "out of range" and could have been produced from noise/spikes from else where in the motorbikes circrtry.
But as I have taken 15 samples, I can now find the average.
So all those numbers added together gives: 27.06
The average is 27.06 / 15 = 1.804 Volts
And this 'filters' out the noise - no need for a delay persay - the time that 15 samples takes is the delay. If you find that this speed is too fast, then put a simple delay in the repeat loop, eg
	Result = 0
	Total = 0
	X = 0
	Repeat
[B]		  DelaymS 1[/B]
		  Result = ADIN 0
		  Result = Result * 2
		  Inc X
	Until X = 15
	Total = Total / 15
And that will help generate a broader time scale for your samples
Thank you
Looks similar to my bike's diagram. Does your bike have three wires to GPS (gear position switch)?
The voltages from the gear position switch should be 'stable' and pretty much spot on as the ECU is using those to choose different ignition and/or fuel maps for first three gears (to prevent 'accidental' wheelies, I guess) and to enforce a speed limit in the top gear (on the GSXR-1000 and Hayabusa).
D.
	Result = 0
	Total = 0
	X = 0
	Repeat
		  Result = ADIN 0
		  Result = Result * 2
		  Inc X
	Until X = 15
	Total = Total / 15
	Result = 0
	Total = 0
	X = 0
	Repeat
[B]		  DelaymS 1[/B]
		  Result = ADIN 0
		  Result = Result * 2
		  Inc X
	Until X = 15
	Total = Total / 15
OK as we say down here in Brazil "living and learning", so can I do the same with speed code below (your code)?
KMHT=Counter PORTC.7, 500 ' I increased the value of period from 250 to 500 but the reading still too sensitive
If KMHT=0 Then Goto Display_speed
Temp_Float=KMHT
Temp_Float=(Temp_Float*2)*8 ' I round 7.2 to 8 which gave me a more accurate speed reading
KMH=Temp_Float/10
KMHT=KMH
Display_speed:
If KMH_Last<>KMHT Then
KMH_Last=KMHT
EndIf
GoTo Start
Thank you again for your valuable help
D.
Yes sir, it has 3 wires and I took the signal from "P" wire near the ECU connector as you can see on the diagram. And as I post before I'm almost sure I have a GPS or generator or regulator problem, first because the voltages overlaps and second because on the bench the circuit works very nice and the only thing I can see strange on this bike is that it drinks a lot of fuel and it's fast, so it may be a indicative of GPS problem and because of that the ECU chose a higher gear (5th) to deal with. I don't know...
I don't think the Suzuki TL1000 has a speed limit but I'm sure it has a RPM limit above 10500 RPM with load.
Thank you
D.
Just for information, I changed the ground of the circuit that I took from somewhere of the instrument cluster and now the circuit is very stable, so the problem was GROUND. The Gear indicator is working perfect... But not the speedometer that when I turn the ignition ON it shows me 10 Km/hr and in 30Km/h shows 60Km/hr and so on, with more speed the difference between analog and digital increase.
I had to change the resistors of the voltage divider from 1k to 10k because with 1K the voltage on the lcd indicator drop about 1.5 Volts.
