Power sensor signal conditioing
Woops typo.! Its this one.:eek:
Adc Value = [Vsig/Vref]*1023
As you are working down close to zero, the -Vref isnt included, just the +Vref
Quick update.
The new proposed diagram worked. The signal is arriving at the PIC as expected. The AD736 is now correct.
As I suspected the AD736 output was not correct.
When clamp not connected the AD736 is zero, however th CA3140 is still showing 5mv on my DMM and 3 on my software..
I tried to connect Pin 1 and Pin 5 to 0V using a 10K pot however this only cut the 5mv in half on my DMMand down to 1 on my program, I know I can allow for it in my program but it will be nice if I can make sure I get zero as output of the CA3140.
Many thanks for all your efforts and time.
Thats good news.:)
Do you a have a low voltage supply on the project, say about -5Vish.?
What tolerance are the two 100K resistors that give the Vs/2.?
They both have a Gold band, which means 0.1 I think.
With regards to -v I do not think the demo board provides -v.
Any other way I can achieve this?
Thats good news.:)
Ideally the CA3140 should be powered from +/- 5V supplies in order to get absolute zero output. Most OPA when working on a single supply will not go to absolute zero. The CA3140 is a good choice for single supplies as will go close to zero output.
I would use the program to remove this small zero offset, the offset value will remain constant over the full output range.
The only other alternative is a another small battery, which is a pain.!
The reason for asking about the 100K's if they were low tolerance, its possible that the junction of the two would not be exactly V/2, which would give a slight dc offset.
Personally I think the results you are getting are OK.
Once the project is laid out on a pcb the noise should be reduced.
I would be interested when you have finished building, to see your test results.
Thanks Eric,
I am already allowing for this in my software. At the moment I am deducting 2 from the values I am reading.
Plugging my laptop charger: is showing a reading of:
AD736 output......CA3140 output......Software output...reference system
2mv....................11.3/11.4mv..........(4 raw) .............. 0.045KW
My watts would be : ((2/10)*240)/1000 = 0.048 KW
Adding my 2000 watts hair dryer to the load:
77mv....................230mv...............( 76 raw)............ 1.790 to 1830KW
My watts would be : ((74/10)*240)/1000 = 1.776 KW
I think those are pretty good figures especially that they match very closely a reference system I am using.
Is it possible for me to send the schematics to someone who can build the PCB for me without remortgaging my home to pay for it :D .
My other alternative is to do it on a veroboard, and I was thinking of adding an LED pushbutton to switch on and off, 2 banana sockets for the clamp and a plug for +5v, Gnd, and output, and place all this in nice case with battery compartment. :D
It would be a good idea to check the actual mains voltage when you doing these calibration tests.
As you know Power = V * I or V^2/R
So if the mains isnt what you think it is, it will throw your results off.
If you want to measure the Wattage of a 'resistive' load you should have a adc channel for the mains voltage.
I would lay the board out on veropcb, its a simple pcb.
I understand there are some freebie strip board layout programs on the web.?
Yes I am using it now.
Seems to be missing an important feature ability to drag components around which is a bit strange. I will check the help and tutorials.
Edit:
Just found it. It is on the bottom right corner 4 arrows :)
EDIT:
Download DIY Layout Creator 1.23 - A useful tool that will help you easily create board layouts for various components - Softpedia
just a quick try, looks a nice easy program to use.
this sample layout of your project has NOT been checked for accuracy
There is missing connection from one end of the 100K's
also whats a 9V led.?
Correct and repost.:)
With exception of the missing 0V line for the supply it looks OK.
Cut the track at the spot marked 'X'
EDIT: just noticed you have linked the 0V near the centre of the pcb
Please find one that I have connected with lines.
I think 0v is already there.
And I am not so sure about the link in the centre.
Please review.
Please review.
Your 'thick' 0V link in the centre is OK, I did notice it after I had posted, so I posted the edit.
You have made decent layout in quick time, that layout program is nice and simple to use.
Consider the LED drain on the 9Vbty.
