mozikluv
i have made an on-time delay timer circuit using the LM555 with R-1.5Mohms and 4.7uf as time determinant. have configured it in astable mode with pin 5 & 7 open.
circuit is used to drive 2 relays in parallel. it functioned as expected. both relays were turned on simultaneously at 9v regulated and 12v unregulated.
now here's the problem: at 12v unregulated, when the circuit is turned off both relay does not cut off simultaneously. but at 9v it does! the time difference between cdut off is about 0.5sec. why :? :? :?
solutions or explanation will be highly appreciated.
heres some voltage and current reading that i have obtained from the circuit:
1. both relay draw 24ma. at 9v and 42ma. at 12v
2. pin 3 voltage is 0.2v w/relay off and 7.6v w/relay on
3. pin 6 voltage w/relay on at initial reading - 7.2v and settles at 4.5v
i know that if i power the circuit with 9v regulated it would solve the problem or i use a DPDT relay would also do. but i would like to use the above set-up and have it powered by the supply of the unit which is 12v unregulated. i dont want to put a 7809 regulated on the circuit board of the delay circuit. pls. dont ask me why.
am willing to try other ways in solving this problem.
thanx in advance.
