Measure tide / swell
stuee
I want to make something to measure swell and tides. Im messing with Raspberry pi 3 and have other sensors working but not sure how to do this one.
The tides mainly go from .0.3m to 4.5m and swell -2m > +2m
I was thinking of a floating sealed ball with an altimeter inside and also temp probe out the bottom a little.
After reading up how altimeters work is on pressure but if its inside a sealed ball would it not work properly, even when it gets warm and may increase the ball pressure a bit.
Am i thinking correct and if so what can it do or anything else i can try?
thanks for your help.
Tides are usually measured with submerged pressure sensors connected to electronics using a cable with an air tube., swell can also be measured in the same way.
E
What is your location.
If you can get an accurate enough gps receiver you might be able to do it measuring altitude.
The sensor is a thin metal diaphragm, one face is exposed to the sea water and the other face exposed to the surface air pressure by means of the air tube.
It is a differential sensor, which compensates for the ambient air pressure which effects the tide/water height.
The sensor sensor is suspended in the water at a depth below the lowest expected level.
In the UK we used sensors 1Bar upto 2.5Bar [ ~ 10mtrs to 25mtrs]
E
E
Hola Eric,
IIRC that was the system used in a vessel to get continuous draft readings even when underway.
How do you get the average value to catter for swell?
hola,
For swell we used 3 axis Heave compensation onboard the Survey/Dredging vessel and applied correction to the water depth measured by the echo sounder in order to get a 'true' depth.
For a quay wall fixed tidal sensor we used tide height averaging .
In some underwater pipe laying projects we had to measure wave heights.
Eric
Hi
I've been playing with this recently, which you might find interesting in parts .. https://njhurst.com/electronics/watersensor/
S
One of the downside of capacitance and resistive sensors was the build up of algae and other crud on the face of the sensors.
A simple fixed height sensor can be made with a ultrasonic surface sounder located inside a stilling tube/well [ a bit of plastic drain pipe works OK].
Using a piece of pipe, a float/counter weight with a cord turning a potentiometer was used in the olden days
E
Hi Eric .. .. .
Yes, I've been reading about the issues and problems caused by build up of algae and the like. I've also read a bit about an ultrasonic solution. For my own purposes I'm actually looking for the means to assess the contents of a fairly modest tank that holds clean water, which is drained and replenished regularly.
I've had a play with capacitive probes with some fairly indifferent results so far, but I'm waiting on the arrival of some bits & pieces to make a more proficient probe. I've also got some ultrasonics on order, but there seems to be an issue with condensation moisture causing circuit failure. There is a solution but it is very expensive.
I wouldn't suggest that the article I appended will offer any solution, but it is a good place to start when discovering the pitfalls.
S
Yes so long as the plastic doesnt contain metal, some abs does.
