Making a motor arc?
lieutenant L
Hi Everyone
Im new to using PCBs etc. as I never have really had to use them - and if I have I tried finding kits to build
What im after is a motor PCB circuit which will fit into a model tank for displaying
I would like the turret of the tank to rotate - so to go to the left, reach a point then go back to the beginning position and go to the right and so on
I have a pager motor which i would prefer to use if possible as the motor
However im unsure how to stop the motor doing a full turn - and just arcing on its own ( I want to leave it - knowing it will keep rotating )
I understand about how to slow down RPM using gears
If anyone could help it would be much appreciated ( hopefully there is a way around using a PCB circuit as i dont know how to make one or have equipment to do it )
thankyou
Luke
p.s. im in england if that means anything for resources etc.
Well...you would need to use an H-bridge circuit to allow the reversal of motor current to change direction. You can PWM the control pulse to the H-bridge circuit to achieve speed control.
As to stopping continuous rotation, you are going to need some form of feedback (as complex as encoders), but if all you need is end-to-end movement, perhaps a tactile switch (with debouncer) on both end points is all that is required.
You could use a latch to make it so that the act of hitting the switch changes the control signal to the H-bridge to achieve the reversal of direction. And you can use something like a 555 timer to supply the PWM H-bridge control pulse to have the motor move at something less than full speed (to move at full speed is pretty obvious). Of course, you can use a PIC or other uC to replace the latch and 555 timer.
I should say though, that it will overshoot by a lot if you want a very fast motion. (With this method, the motor is always moving at a constant speed up to the instant before it hits the tactile switch. Obviously, this is hard on the gears, hard on the switch, and hard on the motor. If a comparitvely large mass is being moved things will get very bad. In any case, regardless of speed, I suggest you use a lever-spring-type switch so that it can give a bit after it is activated (rather than the motor hitting a brick wall). A long lever is probably better since it can give more (just eyeball it, it doesn't matter- just so nothing get's damaged from a direct unabsorbed impact)
If you want fast, smooth and steady motion with minimal overshoot, you need to know the exact position of the motor rather than just left-end-point, right-end-point, and "somwhere in the middle". This requires an encoder or something like a potentiometer linked to the output shaft for position feedback. Along with this comes the ability to position at a specific point between the end points.
Oh, one last thing, it might be just cheaper and easier for you to buy a feather weight RC servo. It comes with motor, gears, and electronics that allow for continous position control (as opposed to end detection only) with smooth, fast motion, and controlled overshoot . It would be $15-25 pounds. I suggest the Hitec HS-65HB or HS-65MG (plastic gear or metal gear). The size is 24x12x24mm. Or there is the even smaller HS-50 11x21x22mm. I highly suggest this method if you don't especially if you do not have the motor yet, or you already have the motor but no gears yet ...finding gears to fit the motor is going to be difficult and expensive.
Keep in mind purely mechanical approaches - a offset CAM on a slowly turning motor (get one of the servo's dk suggests, pull off all the electronics and just attach it to the power supply for a nice slow motor).
Alternatively, you can just use the servo as is and get something like this:
and generate whatever movement pattern you want to without having to make a custom board. It's supposed to be pretty user-friendly to program.
James
Yeah, I suppose you could use more complex mechanics to slow the motor down near the end-points so it doesn't overshoot when using tactile switches. But...then you can just get a servo hehe.
Have you seen that rorary crank where the output will only turn in 90 degree increments (that was used before stepper motors)? That thing is crazy! lol.
I've got a book called "Illustrated Sourcebook of Mechanical Components" which is a big picture book of a bunch of oddball mechanical bits. The thing that does discrete steps is called a https://www.google.com/search?q=geneva+mechanism .
But just doing the thing with a RC servo and a basic stamp(or something similar) is probably the easiest way of doing things.
