how to understand this code!!!
indie
hi there...i have some idea to control the degree of servo motor movement. the basic idea just like this, if i type some number from the keyboard (1...240, depend on the servo resolution), then the servo move to the degree that refer to the number. i have found the driver and the code from **broken link removed** to control servo motor. and right know i make the software to display it to the computer and was done. but the problem is with the assembler code. i still don't understand and can't describe how the code work, because i'm new here... so i can't make the flowchart of it. please help me to describe the code cause i need to give the report to my teacher.
thank's before
INDRA
here is the code
; Servo controller
; Jaap Havinga 16 aug 1999
; Revision 1 25 april 2000
; Revision 2 1 aug 2000 ; serial input can be defined positive or inverted
; Revision 3 24 oct 2000 ; speed doubled to 38400 baud, and resolution doubled also.
; Revision 4 27 dec 2000 ; increased number of servo's to 12. (PB0-7 plus PA0-3)
; Revision 5 13 mar 2001 ; PWD values are stored into eeprom, and read out during initialization
; servo outputs: PB0-7, PA0-3
; serial input : PA4, rs232 pin 3 via 33k resistor (rs 232 pin 5 = ground)
; 4MHz:
; baudrate: 9600, no parity, 8 databits, 1 or 2 stopbits, no control flow
; 20MHz:
; baudrate: 38400, no parity, 8 databits, 1 or 2 stopbits, no control flow
; First sent addressbyte (== servo number),
; then the databyte (== position of servo shaft)
; address = f0..f7 == PB0-7, f8..fB == PA0-3
; data = 0..36 @4Mhz, or 1..239 @ 20MHz (RANGE_TIME/TIMER_PERIOD)
;; PWD values are stored in eeprom, and read out during initialization
;; command for storing PWD's is address 0xff followed by data 0x00
list p=16F84A
include <p16f84a.inc>
; genereer config data
__config _HS_OSC & _PWRTE_ON
; __config _RC_OSC
#define BANK_LOW bcf STATUS,RP0
#define BANK_HIGH bsf STATUS,RP0
; serial input can be defined positive (input direct to standard RS232)
; (NORMAL_SERIAL defined) or inverted (NORMAL_SERIAL NOT defined)
;;#define NORMAL_SERIAL
ifdef NORMAL_SERIAL
#define SER_BITTEST_H btfss
#define SER_BITTEST_L btfsc
else
#define SER_BITTEST_H btfsc
#define SER_BITTEST_L btfss
endif
; timer runs at 1Mhz, for 4MHz PIC version, baudrate = 9600
; timer runs at 5Mhz, for 20MHz PIC version, baudrate = 38400
; define HIGH_SPEED if running on 20 Mhz
#define HIGH_SPEED
ifdef HIGH_SPEED
#define TIMER_PERIOD D'26' ; is defined by baudrate, resolution and the max. number of instructions per interrupt.
#define TIMER_PERIOD_SCALE 5 ; real_timer_period = TIMER_PERIOD/TIMER_PERIOD_SCALE usec
#define BAUDRATE D'38400'
else
#define TIMER_PERIOD_SCALE 1 ; real_timer_period = TIMER_PERIOD/TIMER_PERIOD_SCALE usec
#define BAUDRATE D'9600'
endif
; pulse width modulation for rc-servo motors
#define MIN_PULSE D'800'; in usec
#define MAX_PULSE D'2000'; in usec
#define PULSE_RANGE (MAX_PULSE - MIN_PULSE)
#define INIT_PULSE_COUNT (MIN_PULSE*TIMER_PERIOD_SCALE/TIMER_PERIOD)
#define END_OF_PERIOD_COUNT (PULSE_RANGE*TIMER_PERIOD_SCALE/TIMER_PERIOD)
#define TIMER_CORRECTION_VALUE D'6'
#define TIMERCOUNT (0xff-TIMER_PERIOD+TIMER_CORRECTION_VALUE)
#define PWD_REGISTERS D'8'
#define PWD_REGISTERS_MASK 0x80
; serial interface
; baudrate is 9600/38400
; bit-duration of serial is 1/9600 = 104 usec
; bit-duration of serial is 1/38400 = 26 usec
; oversampling of serial signal should be at least 2 times , higher sampling rate is more reliable
; 1 bit-duration is n timer ticks: n = baudrate / (real_timer_period)
; correct for 2 extra substages!
#define SER_BIT_TIMER ((D'1000000'*TIMER_PERIOD_SCALE)/(BAUDRATE*TIMER_PERIOD))
#define SER_BIT_TICKS SER_BIT_TIMER-D'2'
; The first delay after detection of the startbit is 1.5* de bit-duration
#define SER_FIRST_BIT_TICKS (SER_BIT_TIMER * D'3') / D'2' - D'2'
#define SER_BYTE_SIZE D'8'
#define SER_RX_BIT 0x04 ; A4 is receive bit
; *************** used registers *********************
PWD_BASE equ 0x0B
PWD0 equ 0x0C
PWD1 equ 0x0D
PWD2 equ 0x0E
PWD3 equ 0x0f
PWD4 equ 0x10
PWD5 equ 0x11
PWD6 equ 0x12
PWD7 equ 0x13
PWD8 equ 0x14
PWD9 equ 0x15
PWD10 equ 0x16
PWD11 equ 0x17
PWD12 equ 0x18
PWD13 equ 0x19
PWD14 equ 0x1a
PWD15 equ 0x1b
PWD_STARTUP_COUNTER equ 0x21
EndOfPeriodCount equ 0x22
InitPulseCount equ 0x23
ExtendedPulseCountA equ 0x24
ExtendedPulseCountB equ 0x25
PWD_REGISTER equ 0x26
PWD_REGISTER_MASK equ 0x27
PWD_STATE equ 0x28
SER_STATE equ 0x29
SER_TICK_COUNT equ 0x2a
SER_BIT_COUNT equ 0x2b
SER_PORTA equ 0x2c
SER_DATA equ 0x2d
SER_SET_DATA_ADDR equ 0x2e
SERAddress equ 0x2f
SERData equ 0x30
DecExtRdyCnt equ 0x31
counter1 equ 0x32
#define PWD_STARTUP_COUNT 30
; *************** EEPROM initial data *********************
org 0x2100
DE D'152', D'197', D'123' ; left hip, knee ankle
DE D'104', D'55', D'145' ; right hip, knee ankle
DE D'138' ; hip
DE 0,0,0,0,0,0,0,0,0 ; future use
; *************** Start of program *********************
org 0x00
reset
goto init
org 0x04
irq
movlw TIMERCOUNT ; reload timer
movwf TMR0;
; tmr0 has increased with 6 cycles after irq occured,
; also the reloading of tmr0 will stop the timer for 2 cycles
; So the timer should be corrected by 4+2 = 6 cycles
bcf INTCON,T0IF ; enable irq again
PWD_STATE_DISPATCH
movfw PWD_STATE
movwf PCL
PWD_STATE_WAIT_PERIOD_END
decfsz EndOfPeriodCount,F ; dec main counter
goto SERIAL_DISPATCH ; not zero, continue
;; this state is split up in sections
;; to assure processingtime is within timer-period
PWD_STATE_PERIOD_ENDED
movlw PWD_CONTINUE1 ; set new state
movwf PWD_STATE
CLRWDT ; Clear watchdog! <18 ms!
movlw END_OF_PERIOD_COUNT
movwf EndOfPeriodCount ; yes, reset periodcounter + set outputs high
movlw INIT_PULSE_COUNT
movwf InitPulseCount ; yes, reset initpulsecounter + set outputs high
bcf STATUS,C ; clear carry before shift
rrf PWD_REGISTER_MASK,F ; shift register bit to right
PWD_CONTINUE1
movlw PWD_CONTINUE2 ; set new state
movwf PWD_STATE
decfsz PWD_REGISTER,F ; and decrement register counter
;;;;; goto PWD_CHECK_STARTUP
movlw PWD_REGISTERS ; carry, so real reset register counter
movwf PWD_REGISTER
movlw PWD_REGISTERS_MASK
movwf PWD_REGISTER_MASK
;;;;PWD_CHECK_STARTUP
;;;; decfsz PWD_STARTUP_COUNTER,F ; decrement startup counter
;;;; goto SERIAL_DISPATCH
;;;; movlw PWD_STARTUP_COUNT
;;;; movwf PWD_STARTUP_COUNTER
; this state is a continuation of PWD_CONTINUE1
PWD_CONTINUE2
movlw PWD_CONTINUE3 ; set new state
movwf PWD_STATE
movlw PWD_BASE
addwf PWD_REGISTER,W
movwf FSR
movfw INDF ; load wanted pwd count
movwf ExtendedPulseCountB ; set to ExtendedPulseCountB
; this state is a continuation of PWD_CONTINUE2
PWD_CONTINUE3
movlw PWD_STATE_WAIT_INIT_PULSE ; set new state
movwf PWD_STATE
movlw (PWD_BASE+8)
movwf FSR
movwf ExtendedPulseCountA ; set to ExtendedPulseCountA
movfw PWD_REGISTER_MASK ; set bit of registers A and B to 1
movwf PORTA
movwf PORTB
decfsz InitPulseCount,f
movlw PWD_STATE_WAIT_EXT_PULSE
movwf PWD_STATE
movlw D'2'
movwf DecExtRdyCnt
decfsz ExtendedPulseCountA,f
goto DecExtB
clrf PORTA
decfsz DecExtRdyCnt,f ; ports are zero, so we're ready: set next state
goto DecExtB
goto DecExtRdy
DecExtB
decfsz ExtendedPulseCountB,f
clrf PORTB
DecExtRdy
movlw PWD_STATE_WAIT_PERIOD_END
movwf PWD_STATE
; *************** SERIAL IRQ routines ***************
SERIAL_DISPATCH
movfw SER_STATE
movwf PCL
SER_STATE_DETECT_START
SER_BITTEST_L PORTA,SER_RX_BIT ; current value 0?
retfie ; no, wait
movlw SER_STATE_DETECT_START1 ; wait for 1
movwf SER_STATE
retfie
SER_BITTEST_H PORTA,SER_RX_BIT ; current value 1?
retfie ; no, wait
movlw SER_STATE_RECIEVE ; start detected, so set state to recieve
movwf SER_STATE
movlw SER_FIRST_BIT_TICKS
movwf SER_TICK_COUNT ; reset tickcount
movlw SER_BYTE_SIZE ; how many bits to expect
movwf SER_BIT_COUNT
retfie
;; this state is divided into 3 substages in order to ensure timely return of irq routine
SER_STATE_RECIEVE
decfsz SER_TICK_COUNT,f
retfie ; nothing to do
movfw PORTA ; get data
movwf SER_PORTA ; store for later use
movlw SER_BIT_TICKS
movlw SER_STATE_RECIEVE1
movwf SER_STATE
retfie
SER_STATE_RECIEVE1
SER_BITTEST_H SER_PORTA,SER_RX_BIT ; test data input
bsf STATUS,C ; set carry if data = 0
rrf SER_DATA,F ; rotate carry further to address
movlw SER_STATE_RECIEVE2
movwf SER_STATE
retfie
SER_STATE_RECIEVE2
movwf SER_STATE
decfsz SER_BIT_COUNT,f ; all bits done?
retfie
; All done, next will be stop bit, time to process data
movlw SER_STATE_VERWERK_DATA ;next state is process data
btfss SER_SET_DATA_ADDR,1
movlw SER_STATE_VERWERK_ADDRESS ; or process address
movwf SER_STATE
retfie
movlw SER_STATE_DETECT_START ; address will be processed, so set state to detect start again
movwf SER_STATE
movfw SER_DATA ;; copy data to address field
movwf SERAddress
andlw 0xf0
sublw 0xf0
btfsc STATUS,Z ;; if not zero, so if high nibble <> 0xf0 then not to data bit.
bsf SER_SET_DATA_ADDR,1 ;; set next byte target to data
retfie
movlw SER_STATE_DETECT_START ; data will be processed, so set state to detect start again
movwf SER_STATE
clrf SER_SET_DATA_ADDR ;; set next byte target to address
movfw SERAddress
andlw 0x0f ;; valid address = 0,1,2,..,15
addlw PWD0 ;; add the register-address to it
movwf FSR
sublw (PWD0+0x0f) ;; test if adress 15 is called
btfsc STATUS,Z
goto write_to_eeprom ;; yes write pwd data to eeprom...
movfw SER_DATA ;; no store data
movwf INDF
retfie
write_to_eeprom
movfw SER_DATA ;; extra test: data should be 0
btfss STATUS,Z
retfie
call eewrite_pwd ;; write it!
retfie
; *************** Read eeprom **************
; read address in w
; data in w returned
RD_EEPROM
movwf EEADR ;; set address to read
BANK_HIGH
bsf EECON1,RD ;; fetch it
BANK_LOW
movfw EEDATA ;; and read data
return
; *************** write eeprom **************
; write address in w
; data indirect in indf
; note IRQ is NOT switched on again
; since callee is IRQ routine
WR_EEPROM
movwf EEADR ;; set address to write
movfw INDF ;; get data to write
movwf EEDATA ;; set data to write
CLRWDT ;; clear watchdog
BANK_HIGH
bcf INTCON,GIE ;; IRQ off
bsf EECON1,WREN ;; set write enable
movlw 0x55 ;; special sequence
movwf EECON2
movlw 0xaa
movwf EECON2
bsf EECON1,WR ;; set write flag
;;;; bsf INTCON,GIE ;; enable irq again
waitwr_complete
btfsc EECON1,WR ;; poll wr flag
goto waitwr_complete ;; and wait until wr is low
bcf EECON1,WREN ;; disable write
BANK_LOW
return
;; retrieve pwd data from eeprom
eeread_pwd
movlw D'15' ;; Nb of addresses to read
movwf counter1 ;; is our counter+ source address
movlw PWD15 ;; get start destination address
movwf FSR ;; put it indirect register
eeread_loop
movfw counter1 ;; get source address
call RD_EEPROM ;; get data
movwf INDF ;; save data
movfw counter1 ;; is end reached?
btfsc STATUS,Z
return ;; yes return
decf counter1,f ;; no dec counter + dest address
decf FSR,f
goto eeread_loop ;; and loop again
;; write current pwd data to eeprom
eewrite_pwd
movwf counter1 ;; is our counter+ destination address
movlw PWD15 ;; get start source address
eewrite_loop
movfw counter1 ;; get destination address
call WR_EEPROM ;; write data
btfsc STATUS,Z
decf FSR,f
goto eewrite_loop ;; and loop again
; *************** INIT part ****************
init
BANK_LOW
; *************** init ports ***************
clrf PORTA ; set data A to 0
clrf PORTB
BANK_HIGH
clrf TRISB ; set B to output
movlw 0x10
movwf TRISA ; set A4 to input
BANK_LOW
; *************** SERIAL initialisation ***************
movwf SER_STATE
; *************** PWD timer initialisation ***************
call eeread_pwd
movwf PWD_STATE
movlw 1
movlw PWD_REGISTERS
movwf PWD_REGISTER
movlw TIMERCOUNT ;; initialise timer
movwf TMR0
BANK_HIGH
; *************** 16F84 chip initialisation ***************
; Set chip options
movlw B'11001000' ; PullUp disabled, rb0 rising edge irq, psa to wdt, rate = 0
movwf OPTION_REG
BANK_LOW
CLRWDT ; Clear watchdog! (every 18 msec !!)
bsf INTCON,GIE ; enable interrupts
bsf INTCON,T0IE ; enable timer 0 irq
; *************** main function ***************
loop nop
nop
nop
nop
nop
nop
nop
nop
nop
nop
nop
nop
nop
nop
nop
nop
nop
nop
nop
nop
nop
nop
goto loop ; wait for interrupt
END
I think the code you have here is much more complicated than it needs to be. All the software needs to do is read a couple characters from the serial port, convert them to a binary number and then output a PWM signal. If you get a PIC with a built in UART reading from the serial port is easy. Generating PWM is easy too. The web should have tons of information about how to do these things.
