Hello all, I'm new here. I'm seeking knowledge and advice about a Lithium ion battery bank that I made. I got these batteries from work out of a device that we replaced the batteries on. It is a somewhat proprietary battery as it is made specifically for this device and not open to the general market and I have limited knowledge of the specs outside of voltage and mA hours.
It is made up of 10 batteries at 7.4V each and 1900mA hours a piece.
5 batteries are in parallel and each bank of 5 is wired in series making a battery bank of 9.5 Amp hours and 14.8 Volts. They are already soldered up and are sitting at about 16V's.
Now a little bit more about the batteries, each battery pack is actually made up of 2 smaller batteries in series. Attached to this pack is a small circuit board which I believe is some kind of protection circuit but I'm not really sure. There is also 3 wires coming off of this battery. A black a red and a yellow. Red is positive but it also seems to be the common. Red and black reads about 8.3V. Red and yellow reads about 7.6. And black and yellow reads 0V. I wired up this battery using red and black and ignoring yellow as it was a smaller voltage and I didn't know what it did.
The "stock" charger for one of these batteries is 10VDC at like 1.8 amps if I remember correctly.
I'm wanting to use this battery for a fish finder or whatever I find use for it. I have a 2 year degree in biomedical electronics but it's only enough knowledge to get me into trouble haha. My concerns are safety and here are some of the questions below.
1) What do you think the circuit board attached to the battery is?
2) What do you think the yellow wire is used for? Some sort of feedback? Just another power source for something on the device to run off of?
3) How can I charge this bank? I don't even need this battery to be at full voltage as the depth finder is a 12V device (max voltage is 17V). Will hooking up my 12VDC 500mA charger be sufficient enough to keep this thing charged and not blow up on me? I'm not looking for ideal here just enough to keep this thing going.
4) Does the circuit board on the batteries require feedback to work properly?
5) Should I get a 14.8V smart charger or do I just need a 7.4V smart charger? Or should I take one of the power supplies that is made for these batteries and hook it up?
That is all I can think of for now. The battery is stable but I'm not going to hook it up to anything or try and charge it until I know it's safe.
