When mounting a heatsink to the Transistors of an amp say around 200W Max, Is it advisable to have the Transistors & thermal washers on one side of a sheetmetal chassis & the heatsink on the other side of the steel chassis?
So the chassis is sandwiched between the transistors & the heatsink--see attached drawing..
With it done this way how efficient is it compared to having the Transistors mounted directly to the heatsink.
Would it be better if the chassis was aluminium sheet?
Cheers
Cheers
