On my old car with a dynamo, the voltage setting is much higher than would be expected from an alternator system.
This guide:- https://www.trtriumph.com/Regulator adjustment.pdf has the voltages around 16 V. Another guide was a bit less at higher temperatures:-
10°C (50°F) 16.1 ‐ 16.7 V
20°C (68°F) 15.8 ‐ 16.4 V
30°C (86°F) 15.6 ‐ 16.2 V
40°C (104°F) 15.3 ‐ 15.9 V
Logging on the car showed 16.7 - 16.9 V when driving, without much in the way of electrical load. At first I thought that this showed that the regulator was not working at all well, but having seen the suggested settings, the voltage is maybe a bit higher than originally, but really a lot higher than on a modern car.
Obviously the battery is modern*. Should I be looking to reduce the voltage somewhat to avoid damaging the battery?
I know that I might get a lower rate of charge when running if the voltage is lower, but it's not as though the dynamo will keep up with the electrical loads in stop-start driving at night, just like the previous car I had with a dynamo. I leave a charger connected when the car isn't in use.
*Remarkably, the batteries and terminals haven't changed dimensions. I just needed to drill each battery terminal to take the screw that holds the connector to the terminal.
