Q: A precision pressure sensor produced an output voltage according to the equation: Vs=(P X 13)mV+1683 mV or P=(Vs -1632) / 131. Use a combination of inverting amplifiers,non-inverting amplifiers and !V reference voltage sources to implement the amplifier for the sensor such that it will produce an output such that Vo=P,for the range from -10 psi tp + 10 psi,where Vo is the output voltage in volt and P is in pressure measure in psi(ie Vo=+,- 10 V
