It can only hold the output when it is not counting. If you need to hold the previous value while counting, you will need a counter with output latches such as the CD40110.
I not referring to holding the data when the clock is disabled. All counters do that.
The 4511 has a latch, so that, along with the 4510, will also hold the last count while you are doing the next count (with the proper latch signal).
