RL circuit practice
Series C values are as I stated correctly, in other words 1/C = 1/C1 + 1/C2
Also the OP & I were the ones who pointed out using high R reduces error, while you insisted on using an R lower than DCR
Meanwhile as a Test Engineer for 35 yrs, I know of no instrument using the RL method and LC method with resonance or oscillation is preferred.
I also have 15yrs of R&D experience in analog systems alone
Yes, the formula for series capacitance was never in doubt. I just wanted to confirm whether you meant series or parallel in the circuit. The capacitor placement in the circuit is ambiguous as to whether they are in series or parallel.
No you all didn't. I talked about using a 10K resistor to swamp out the coil resistor as early as post #7. Unfortunately, the OP's generator was not able to generate the frequency needed. I suggested a lower resistance and lower frequency to eliminate the high frequency effects.
Good, then you will understand what I am talking about.
I never said the TC method was the best way to measure inductance. I only suggested it as a simpler alternative.
And I respect that. Do you now agree that L = 1/(w^2)*C) for series resonance? You seemed to disagree about that in a previous post.
Ratch
Even if ground is between two caps in series, it is not ambiguous to the experienced. Why did you doubt me?
Because the op-amp output goes to the right-side capacitor and simultaneously to the left side capacitor through a resistor and coil. That is the parallel perspective. The series perspective is around the loop. I wanted to know which way you were calculating the capacitors.
You still have not answered the question of what is the correct formula for series resonance.
Ratch
I see I need to correct your false assumptions.
1) it is not an Op Amp, rather a logic gate
2) it is not a series resonant circuit.
It is a parallel resonant circuit with series caps.
Thanks for pointing out my typo
ω²=1 / (LC)
L = 1 / (ω²C)
L = 1 / {(2πf)²C}
A overdriven inverting Op Amp could be made to do the same thing functionally.
Now that I examined it better, I don't think it is either a series or parallel resonant circuit. It looks more like an electronic multi-vibrator to me, which is not a linear oscillator.
In some equipment, like power supplies, there are many capacitors connected to ground. You would not say those capacitors are in series, would you?
ω²=1 / (LC)
L = 1 / (ω²C)
L = 1 / {(2πf)²C}
Glad to do it.
Ratch
Glad to do it.
Ratch
1. OP Amp ? Not , never
as Op Amp as I had shown at that f.
Op Amps are integrators (1/f response) and not broadband linear CMOS amplifiers with high gain (10 per stage of 3) at 10Mhz
- thus useless for high f oscillators for measuring LC resonance
2. electronic multi-vibrator ? Not , never
It is not a relaxation oscillator or "multi-vibrator" or "astable".
It is a linear resonant circuit amplifier up the point until output saturates into a square wave since the gain at resonance is >>1 with Barkhousen criteria satisfied for oscillation. So there is a sine wave output feedback after the bandpass parallel filter with 180 phase shift and the logic inverter is 180 phase shift resulting in 360 deg loop phase at resonance. The inductor self biases input DC for 50% duty cycle. this is a "101" oscillator circuit design
3. parallel caps on supply? series? no not never
this is an obvious error in your implied critical comments. They are shorted at each end,
This design has an inductor between each cap. ( which has equal magnitude of impedance at resonance)
Allow me to redraw for you to understand.
https://www.falstad.com/circuit/circuitjs.html?cct=$+16+5.000000000000001e-11+10.20027730826997+50+5+43 r+160+512+288+512+0+1000 w+288+512+288+544+0 c+352+544+288+544+0+1.5e-9+-0.4342750419355297 l+288+512+400+512+0+0.000001+-0.07080797846745183 c+400+544+352+544+0+1.5e-9+4.571412541865394 w+400+512+400+544+0 I+400+592+160+592+0+0.5 g+352+544+352+560+0 w+400+544+400+592+0 w+160+512+160+592+0 o+9+64+0+298+5+0.0015625+0+-1 o+8+64+0+290+5+0.00009765625+1+-1
moreover if you analyze the above link and press RESET, you can see the startup performance for DC self-bias, Step Input broad-band noise, resonant output which is amplified in a linear fashion when Vcc/2 or 2.5V is reached and then operates in pure linear mode until saturation of output.
This is identical with all Pierce Crystal Oscillators
https://en.wikipedia.org/wiki/Pierce_oscillator
capiche?
The linear aspects of a logic gate are easily misunderstood. Gain is fixed below to unity gain by 1:1 R ratio added to above oscillator to make a "sine wave buffer" ,
In LC resonator the feedback gain it is affected by Q ratio. = R/X(f)
https://goo.gl/8V1qJd
Functionally speaking, it is a overdriven inverting amplifier, even if an Op-Amp is not capable of reaching those frequencies.
By any other name, it looks like a pulsed Colpitts oscillator. The output, when using a gate, looks like a rounded triangular wave, not a nice sine wave.
Some power supplies have inductors between each filter cap also.
Ratch
Ratch , your comments are incorrect or irrelevant.
1. Functionally speaking, it is a overdriven inverting amplifier,
This would imply external input.
This is a resonant oscillator not a multi-vibrator
I stand by my comments, No Not never.
Your arguments deflect your errors and conflict with general wisdom of experienced designers.
Fallacious at best.
Again you make fallacious irrelevant comparisons to deflect admitting your errors.
The Colpits Osc. is not what I demonstrated . That design uses non-inverting amplifier.
i.e. 180 phase inverted amplifier is used for Pierce Osc.
When saturated output with high gain, it is also the common uC PIC square wave clock with external reactive element such as LC, crystal or tuning fork.
a Colpitts or a Multi-vibrator
No, not! , never
In what way? Just saying so does not make it so.
External input? No more so than the gate does.
Yes, there is resonance involved, like there is for many nonlinear oscillators. You even said that there is saturation involved. So if you don't want to call it a multi-vibrator, then perhaps a switching oscillator would be a better descriptive.
I think you mean to say, "No, not ever".
Fallacious at best.
You can say anything, but you should describe and prove what you say.
Ratch
Again you say things but don't back them up.
Your submission still uses a inductor with a cap at each end. Instead of connecting the caps together and then to ground, connect them to ground directly. Now it looks like the pi filter of cap--inductor--cap, like so many power supplies used to do. You drive your circuit at a different point than the Colpitts does, but it still uses the same basic circuit.
No, not! , never
It is matter of perspective.
Ratch
capiche?
How does all this relate to the capacitors being in series when the topology shows them to be connected in parallel.
How come the output does not look like a nice sine wave. Instead it looks like a rounded triangle wave.
What does 5 volts on the 1.5 nf capacitor do for anything?
Ratch
Dear Hopeless;
-granted there are similarities, but the Colpitts is in-phase and the Pierce is anti-phase.
-big difference
Neither above is called https://en.wikipedia.org/wiki/Multivibrator
There is no rounded triangle in my simulation.
Only a slew rated limited square wave , which can be edited at will.
I will go with that.
I never called a Colpitts a multi-vibrator. I believe I changed the name of your circuit to a switching oscillator in a previous post. A multi-vibrator is a type of switching oscillator.
It just does not look like a good sine wave. Hopefully, the real circuit does.
Ratch
Ratch
You incorrectly identified the classic design as an electronic multi-vibrator
The sine wave is very clean but the Simulation time sampling gives quantization effects which can be reduced by reducing the sample time. in Options > other options but then unlike digital scope this has less memory. For better slew rate , I edited the gate to be faster below.
I changed one cap to pullup and one to ground to speed up the startup DC bias.. Same f results as Vcc to ground ~0 Ohms impedance
Ratch
I simulated this in LTSpice, L=10ouH C1=C2=10nF using 74HCU04 as inverter, frequency ~ 225kHz and the second harmonic measured from input pin was about 0.3% and from output pin about 3%
Edit: corrected the value of L
Not bad, thanks for the confirmation jjw.
I think Q affects harmonic rejection and THD with the values selected.
As stated the design was a starting place for measure L.
For improved THD, Q can be increased and linear gain adjusted.
There are subtle differences with U04 types and Buffered types with spurious potential with overtones, but 3 stages of gain can extend range of operation for low Q inductor tests. U type is recommended for crystals but often Buffered (B) types work well too.
