What relay could i use?
I'm trying to activate an electrical deivce using DTMF signals. I found a circuit that i attached which uses a relay each to turn the electrical devices (device 1, device 2 & device 3) on/off. Could someone tell me what type of relay is this and where i can find a datasheet for it? Thanks.
The relays are connected to 5V, so the relay coils must be 5Vdc.
As the coils are driven by transistors any general purpose relay coil would do.
The contact rating of the relays will depend upon what voltages and currents are being switched.. what are the devices being controlled.?
Devices to be controlled
Any external electrical device such as an air conditoin, lamp, oven, heater etc...
Thanks. I looking at a relay i found used in a project right now. The RY5W-K from Fujitsu.
Whats the specification of the relay, I couldnt find the datasheet.
Datasheet
I attached the datasheet. This should work for my application right?
  • RY5W-K Relay.pdf
The current rating of the contact is low.
Max load current is only 1 amp,, 64VA @ 120Vac
Its not suitable for: air conditoin, oven, heater
It would be OK for a 120Vac, 60Watt lamp.
You could use the contacts to operate more powerful relays.
Ok thanks. Is there a relay you could suggest i use that could activate an air condition or oven or such high powered device? I'm very much new to this. Thanks
There is this type:
MULTICOMP|HRM-S DC5V|RELAY, PCB, SPCO, 5VDC | Farnell United Kingdom
What are the operating current/voltages of the equipment you want to switch.?
You could also consider SSR [solid state relays].
EDIT:
Using the above relays, you would have to upgrade the BC547 transistors to say, 2N2222
Relay
I'm looking for The 5Y5W-K Relay mentioned above to purchase...Or any other relay with same specification that capable of controlling a lamp. Any links where i could purchase any relay to do such would be much appreciated.
Thanks.
Relay
Here is the data sheet of FINDER.
It's written in German. Wechsler means changeover
This type can switch 16A.
It should also be available at Mouser and Digikey.
Boncuk
  • S40DE.pdf
Use the 5V relay to activate a power relay. 12 and 24V coils have much more power than 5V relays which are commonly used for signal transmitting.
The higher the coil power the faster and tighter close the contactors, hence less contact burning will occur switching high current devices like heaters and coolers.
Boncuk
