I am looking for a 200 amp 240 volt AC Normally Open NO compact relay for a new device I am prototyping. Something similar in size to a car starter relay but 24 volt coil and normally closed. I will need to get UL listed so quality matters over cost.
As long as the coil is 24 volts AC, all of the major contactor manufacturers should offer them.
Eaton, Schneider, ABB, Danfoss, Fuji, Siemens, Potter & Brumfield and many others.
Although your Normally Closed requirements will narrow your choice.
Do a parametric search in industrial equipment distributors like Grainger.
I've seen industrial gear in the past, but it is getting rare, as the typical use was a brake contact for use with a large DC motor, to connect a brake resistor across the armature when it was stopped.
Thank you for the lead! It is getting closer to what I want. I do not need (or want) the NO part but for a test piece I could use it but need 24 VAC or 120 VAC. I checked the website (United Kingdom but that would be ok) but no longer available. I will try to track down the MFG to see if they can make one. Thinking of trying to take one apart and have a chassis 3D printed for normally closed. Any leads on some who does that would be appreciated.
Thank you! Great to know what to search for. They do have the NC model but out of stock. I will keep checking other suppliers now that I know what to search for.
