What is the Capacitor value to put here?
Suraj143
Active Member
Hi guys I’m going to connect this circuit to the telephone line. Can you tell me what’s the capacitor & resistor value must used in this circuit?
Can I use a 0.1 uF 250V ?
Hai Suraj143,
Try a 0.47 /250V dc or 160V AC -- Polysterene or polycarbonate type caps.there are BOX type caps in the market. you may recover from your unused or scrap also a cap of similar type.
Sarma
Thanks a lot mvs sarma is there any relationship with the value that I use.
I'll try to place a 0.47/250V cap.But can I place a 0.1/250 V cap?
here is the picture of what I have.It's a 0.1/250 V cap.
thanks
thanks
The 1uF cap has a capacitive reactance to the 'ring' signal frequency, 10 times lower than the 0.1uF you are considering.
Its therefore possible with a 0.1uF, that you will not drive the opto-tx hard enough to trigger the opto detector.
You could try the 0.1uF on the bench, it will not damage anything within the circuit.
Eric
thanks
the value has to be designed for delivering requisite current into the opto 's diode. lower the cap value, less the current , the circuit can deliver( due to higher impedance- you already have a series resistor)try out experimentally as suggested by Ericgibbs.
Sarma
Thanks a lot Eric & Sarma I changed the value to 1uF/250V, little bit bigger than the 0.1uF/250V.Anyway its working very well.
Thanks a lot.
