kernelpanic
I recently had a 4 ton heat pump installed at my home. My thermostat has a set point based on outside temperature where it switches from the heat pump to backup fossil fuel heat. The set point should be determined by the relative costs of the two heat sources at a given temp. One factor that makes this more difficult is the heat pump will go into defrost cycle whenever it determines it is necessary. Essentially this runs an AC cycle.
The HP has a low voltage terminal that energizes during the defrost cycle. This can be used to activate backup heat during a defrost cycle.
I am wondering if there is an easy way to attach a time meter to this terminal so I can record how long it has been active. I would use this information in my calculation to determine the optimal temperature to kick in the fossil fuel backup.
Thanks,
Sean
Thanks,
Sean
