ULN2803 doesn't turn off
Menticol
Active Member
Hello again guys!
I'm having some problems with my parallel port + ULN2803 setup. When I connected my stepper motor all the coils were continuously activated, no matter the status of the parallel port pins.
The problem repeats using another ULN2803, a resistive load (12 light bulb) and a +5v power supply for the controlling pin (replacing the parallel port signal). Result is the same, bulb keeps continuously ON. Connecting or disconnecting the control pin just increases the bulb brightness a little bit.
Attached is the schematic of what I'm trying to do. Any help will be extremely appreciated.
Hello again guys!
Pin 10 has to connect to +12V if you have an inductive load. Otherwise, you can leave it floating. As you have it now, your current is flowing from +12V, through the load, through the diode, and to ground.
That's not my understanding of the IC requirements. Pin 10 must connect to +12V regardless of load type, because the IC outputs are open-collector.
Thank you so much Ron, It worked like a charm! Without your help the project presentation would be failed.
I'm sorry for taking so long to answer.
What do you think the consequences would be if pin 10 were left open on a unit where all loads were resistive??
Sorry by invading the conversation, I tried it, and the resistive load worked normally.
Oops, my bad. No consequence. :o Brain not engaged.
