Sorry. I guess i did not get up early enough. lol
I was trying to see what those SMD caps (resistors) were/are already on the board, and how they are connected(?)
Maybe what you ordered is already there?
haha. enjoy your saturdayI hop those are values and not quatities.
if they are they are invisible.Maybe what you ordered is already there?
i did add both caps (10uf & 0.1uf) to the circuitC1/C2 should be added if they don't exist.
what do you think of using this. maybe in series with a 10pf capKeep in mind that the 30pf cap may need to change
thank you. so ok to use in parallel with a 10pf smdJust the opposite for resistors.
so the updated de will look like this. The ground will be applied in the copper pourcapacitors in parallel add
adjusting pin to ground) so when i adjust it the metal screwdriver does not interfere with it.
I see. Shame. The VC seemed so cool.Fixed is always better.
a better question is should i use a trimmer cap?
i understand that just because it is a capacitor it may not be practical in this circuit.
im just not able to get the range of fixed caps i need and looking for an alternative.
the aussie in this video has suggested i connect this in a particular way (adjusting pin to ground) so when i adjust it the metal screwdriver does not interfere with it.
Moving c5 (10-30pf) over to PAD IN. your so right about that. Good catch.The signal source is the Touch pad, so I'd move the 30pf cap over next to the header pin labeled "PAD" and connect it there.
What is C6 (next to Jumper B)?
BTW- Keep the wire twisted together from the TP to the PCB.
C6 is (was) going to be the Var Cap (4-40pf)
I've been told its better to use fixed so thats out now.
My next Q. Can I use mono lead type caps? I can get them 10,20,30,40pf. (Like in the photo #31) the SMD versions are not available in the sizes I need. Thank you.
