What do you expect the "collector output" that "shows up" to be?I was hoping the collector output would show up and start at 1.2 seconds.
It flows where ever you design it to do so, and depends on what you consider current flow?.Usually in NPN transistors current flows from collector to emitter?
It flows by the laws of Physics. Your design, is what you want it to do. When your design does not work the way you want, then you probably are butting heads against a law you don't understand.It flows where ever you design it to do so
There is a continual fight over if current flows from + to - or from - to +. (electrons are negative)what you consider current flow?
Because the Collector is connected to V2 the collector voltage will look just like V2 voltage.I was hoping the collector output would show up
Electrons are negative, true. If you want to talk about moving electrons, you should be calling it "electron flow". There is no doubt in my mind that Positive current flow is from + to - and anyone who wants to argue over it is a pedantic idiot and not worth my time. (I realize you are just clarifying - and clearly not an idiot - but have you seen the "textbook" on that other Electronics website? What a bunch of tools over there).It flows by the laws of Physics. Your design, is what you want it to do. When your design does not work the way you want, then you probably are butting heads against a law you don't understand.
Tools are every where.bunch of tools over there
Too bad you can't just switch the leads of the meter on the bank account values to turn those frowns upside down.Tools are every where.
Most people think I am a .......
The current flow question is much like the bank and I. I think in $ and the bank thinks in debt. So debt flows from one person to another very much like money flows but in the reverse direction.
