Touch Lamp
Crafty42
Ok, so I'm at it again, trying to fix a touch lamp in the house. It works only when plugged in, and used to be a touch lamp with 3 settings. Weird thing is that if I run my finger up and down the lamp, it feels like it's vibrating, making me think there's some kinda short or something with the sensor, but how can I check or what can I do to fix it?
Thanks!
Ok, I found some info on testing the TRIAC, but I need someone to dumb it down for me.
https://www.circuitstoday.com/how-to-test-a-triac
https://www.electro-tech-online.com/custompdfs/2009/12/1012.pdf
Buy a new one.... It'll cost less than than the component replacement cost and time required.
Hmmm. Sounds like you might be getting a bit of a shock off of it. Be careful. Generally, on these touch lamps, the only thing standing between you and the AC mains voltage is a small pF capacitor. Not a repair I would recommend for a beginner. So if you are one, follow Sceadwian's advice.
How to test a triac.
The circuit above, using 12Vdc, is a good simple test circuit. The explanation is a little off, but the idea is correct:
With S2 ON, momentarily pushing S1 should light the lamp and it should stay lit until S2 is turned OFF and the ON again. Not a 100% bullet proof test, but good enough for practical purposes.
Thanks, I gave it a try and wasn't getting a reading (open circuit) on the first test, so I'm going to give a new TRIAC a try when I find where and time to get one. As for the shock...no, it's not a shock, but it certainly feels like some juice is running, just not enough to shock me. Easiest would be to just buy a new board already set up and just re-run the wiring to it, but I'll have to find where to get that as well.
