I have an idea to encase a toroid inside of a larger toroidal shell, and make the inner toroid out of disc magnets all attached to each other north pole to south pole, and then put a coil around the outer toroidal shell, which if energized with DC voltage with proper opposite polarity to the inner toroid magnets, would induce a magnetic field into the inner toroid magnets, causing the inner toroid to rotate. If the inner toroid rotates, then magnetic flux is induced into the outer coil, generating electricity. This is all theoretical of course... the big question is- if the outer coils were instead permanent magnets (donut magnets) opposing the inner toroid magnets, would the inner toroid move perpetually?
*note outer coils not designated in diagram, but you can see them, they surround the toroid on the left
the middle toroid is the inner toroid (inner toroidal "shaft")
