A person on eBay is selling a "spares or repairs" VCR with a:
"Broken mains switch that doesn't latch"
Could someone explain to me what means?
As you can see in pictures 3 and 4, the power switch is a mechanically alternate action type. Press once, and it stays indented when power is on. Press again, and it extends upon release, and power is off.
The description in post #1 means that the switch works electrically but not mechanically. The unit runs as long as you hold in the power switch.
ak
OK, ***semi***-broken. Mechanically broken, electrically ok.
ak
I only see a switch to toggle between 120 or 240 on the back so it makes sense they mean the "main" front power button that turns it on and off which happens to be of the latching type..You missed the point - it's NOT a mains switch
The only latching power button I see is the power on/off buttons on the front.A person on eBay is selling a "spares or repairs" VCR with a:
We have industrial momentary switches on our testbeds, the technicians have found that a flat blade automotive fuse is just the right size to wedge in the alarm silence switch to keep it turned off .....I've also seem them jammed with matchsticks by the customer
I bought a second hand Sony C5 back in the early 80's when I was a youngster. I had to cycle 10 miles back with it on my pushbike. It used to have a fault that more often than not it would refuse to play, a wiggle of all the boards inside usually got it working temporarily again. They were good old daysIt's going back a VERY long time since I've seen a C7 - but I've got a vague recollection that they might have had a rocker mains switch on the rear.
