I have attached an image.
I have 2 voltage sources coming in the circuit (X and Y). If voltage is present on X, then Y is not needed. X takes priority in this circuit, so Y is only used if no voltage is present at X.
Currently, I am using a mechanical switch as in the top diagram. I want to get away from this; however, I need 5v at Z whether using X or Y.
If I use a transistor, such as a PNP, in the lower diagram, which would tell me if X is off, then I would have to use a Diode on X to prevent the voltage from Y altering the state of the transistor. When I add the diode, I will get a minimum of a .6 voltage drop which I cannot have. I must have 5 volts at Z.
I'm looking for solutions.
Thanks!
Thanks!
