Hello,
In the process of troubleshooting my synthesizer, I measured the output of it's simple +/-15v power supply. For some reason I had the meter set to read A/C, and it read around 32v on the positive 15v output! Why? I checked points back to behind the LM317 voltage regulator, the positive side of the full wave rectifier read 64v ac!! Why? The negative side of the diode bridge read 0v ac as it should. I began to frantically try to understand what was going on. Diodes are not supposed to pass A/C right?
Anyhow, I simplified the whole thing and just tested one diode by placing it in series with one end of the transformer secondary, connecting the centre tap to the black lead of the meter - the red lead to the striped end of the diode. Reading 20v ac and around 9v dc Why? reversing the diode gave the correct reading of 0v ac and -9v dc. Why? So I flipped the red and black leads and tested both directions of the diode again. Results reversed.
I would not expect so much ac voltage (ripple?) and comparatively little dc.
Can anyone explain to me why I am reading so much a/c voltage and relatively little dc, AFTER the diode, and only when the diode is oriented for positive rectification?
-Jim
-Jim
