Tiny bit of background info, sooner or later most large energy production methods, literally boil down to steam (pun intended). As part of something else we are looking for a steam engine to borrow, a small model one.
While chatting about this the conversation drifted onto what would be better in a Bio Methane system for producing both power and heat. First reactions were we all voted modern turbine system (no real surprise), so for a bit of fun we looked at the plans for the new system.
The intention was simply to estimate how much better modern system would work over old steam engine types. To save alot of effort i will skip to near the end bit. Having looked at all the various processes involved with the new digestors, it may actually be more efficient to use a fixed bed steam engine (methane fired). And a methane/lpg type generator for when the steam engine heat side was needed.
The reasons are many, some are to do with pre processing abd some with post processes. Its mainly the mechanical side and the adaptations you could add, these are known to up efficiency in digestor system but are normally done different ways. On the lab scale its hard to prove this conclusively, mainly because even a model steam engine needs alot of energy to bring upto temperature.
But there is no reason you couldnt pre heat some of the water in the engine and take that into consideration when doing the figures. If i do get hold of a old steam engine then those with access to the methane reactor page, might well get to see how it would used. Failing that if we can do some more modeling in matlab, it might be worth getting a custom one built to try out (tiny scale).
The reason for pre heating is so we can keep down the amount of gas we need to keep in the lab inside the reactors. Currently for pre treatment we use other means to get the same effect, on a small scale like that its easier and safer but proves the concept anyway. Just as an aside, if it worked on the lab scale then upgrading to trial size would mean you could use a custom built engine to get the figures.
Same with turbines, we dont use real turbine to make electric from lab scale, we heat water and measure energy produced compared to gas produced and energy used etc. So its roughly the same thing. Just before doing the post it occurred to me, it might also provide a way to use some the waste oxygen from one the microbial cell processes. I will post the pics and info here if we go that route (well what info i can post).
Another side note, I get to visit a liquid salt boiler at a uni in a few weeks time. Brave people working with a molten salt at that temp!!
