serial rs232 cable help?
BryWY
I am wondering if you could take a few minutes to assist me as I am in a bit of a bind ...I live in a remote area where I do not have access to a computer outlet where I can go out an buy a replacment cable for my Desay master vinyl plotter which I have pending jobs get done asap.
I accidently broke the male end going to my plotter off my cable. I found a generic male end all wires one color I would like to use. So I spliced the cable and found there are 7 wires in the cable red white brown green blue yellow and copper on outside.
I am wondering where I can g to find the correct wiring configuration ...any assistance you could provide would be much appreciated.
Search the internet for "serial cable pin out"
There are two options. In this picture 2-3 and 3-2. But some are 2-2 and 3-3.
A few things would help:
Assume serial
Assume D style connectors
In this case, pins or sockets determine male or female
Post a pic of the plotter connector
You can't screw up RS232 in terms of connections. You won't hurt anything if they are connected wrong. Manufactures have made lots of mistakes over the years.
1. Pins or sockets in the connector on the plotter
2. # of pins (could be 9 or 25)
1. Assume 9 pin on the PC, possibly through a USB to serial converter?
2. Probably few things woul a 9 pin male
3. They are eroneously called a DB-9, but they are really DE-9 connectors.
If you know if the plotter is a DTE or DCE device that would be cool.
So, you likely need
DTR
DSR
TXD
RXD
SG
DSR
DTR
PG (protective ground or the shield) - One side only is good
If you can measure the voltage from SG to DSR nd SG to DTR with the plotter on, that should tell us if it's a DTE or DCE.
You likely need a standard serial printer cable to either a 9 pin or 25 pin connector.
The gender used to work
Believe it or not, the wires may actually have numbers written on them. Look carefullly.
It is 9 pin ...male from plotter to pc 9 pin female (I would like to convert it to usb eventually) to use it on my laptop.
Tried standard universal did not work says on plotter must be sr 232...will double check
will post pic in a few minutes....
Rs232 is the most abused non-standard "standard that ever was.
I am not quite sure what you are saying here, are you describing the cable?
However, I guess that on the computer is a 9 pin male connector, if the connector on the plotter is a 9 pin female, try a straight through connection.
ie.
Pin 1 to pin 1
Pin 2 to pin 2
etc, all the way to
Pin 9 to pin 9
You don't need pin #1 or Pin #9. That will give you 7.
Ideally, the shield can go to one of the chassis at ONE end only.
Straight thru makes the most sense. 2-2 ; 3-3...8-8
just tested the regular generic serial cable that doesn't work with and it is pin for pin straight through so must be a null modem cable
Null modem is not straight through, the connections are crossed for handshake etc. As in post #2.
Max.
just checked pin 5 and 7 with volt setting on 10 dc made needle redline....not exactly sure how to use vom
Be careful: The Pin numbering is weird and not expected.
Your empty pins should be one on one row and one on the other at opposite ends. (diagonal).
my little ribbon cable that i plug in plotter male has number one pin with white stripe...now what configuration would you suggest i try?
The REAL Rs232 had voltages of -25 and +25; Typically you see +12 and -12. Between +3 and -3 is the dead zone. Things get weird when the levels are +-5V and thing get weirder yet when you have inverted TTL 3.3 and 5V. You should never see that.
I'm initially interested in pin 5 to 4 and pin 5 to 6 on the plotter. Pin 5 is likely connected to chassis. No cable attached, but plotter on.
We definitely need a couple of pictures. There is an Upload a File.
So, your plugging in a 9 pin ribbon to a 9 pin ribbon with D connectors on them?
Basically, they are meant to be squished together because they are IDC or Interdigitated contacts. They don't make very good null modem cables.
the cable that worked and the ribbon cable temporary fix
