Note: This feature currently requires accessing the site using the built-in Safari browser.
Presumably, providing the failure is due to those parts. Do you have a multimeter to check them? Have you checked the fuse in that circuit?would just replacing the motor and cables on the old unit work
Yes, I believe too he is talking about the “window regulator”.I believe he's talking about the "window regulator" which is a fancy (and official) term for the assembly that raises and lowers the window.
The window regulator I am familiar with is a scissors lift that raises the window. The failure mode I am familiar with is a weld breaking in the mechanical assembly, so the window isn't lift from each end.
So the failure options are:
• mechanical – broken or worn bearings and other parts
• motor – failure to turn at all or slop and grinding noises
• control system – motor is not energized
