Reed Switch Question
b_reagle
I would like to know the part number for a magnetic reed switch that handles around 20mA.
I would also like to know if this is a good way of sensing an object. Here is the circuit.
Sure, magnets are a good way to flip a reed switch.
Well looking at a typical reed switch data sheet
they do seem to have bounce issues which may cause an input to your gate as shown in attached photo. This may present a problem depending on what your gate is driving like a flipflop, again may not.
If you wish to eliminate switch bounce issues read here.
The gate runs a MOSFET which runs a motor. Can bounce be acceptable? The magnet is on the door jam and the switch is on the front door. Door is either open or shut, and I don't think it will be an issue.
The bounce should not be a big deal in such a case. But I do have concern about undershoot blowing your gates input. To be safe, I would add a RC shunt to ground on the gate. See image.
I have an x-tra D Flip Flop (1/2 74HC74). I think there is a way to use it. Is that 10k and 110 ohm's for the R's. Thanks
R1 and C1 is what I am talking about. They make up a filter and will reduce poop on your gates input :) Back in my design days, I would use that configuration a lot as a precaution.
You can ignore the rest of my circuit as I only meant to show the filter...
Sounds good. Will it work 6vdc to 3 vdc. If so how do you determine R1's and C1's values?
Is this a good way of eliminating bounce in the switch? Are the R's the right value? Or am I going about it all wrong?
OK, You should also ground 11/12 pins
I assume the resistors are pullups to +V.?
Yes, R's are used for pullups.
