pulse generator
patroclus
I built a simple pulse generator with a 4MHz crystal and a 4060 counter, to get several output frequencies. I checked them in my scope, and I get quite good pulses, with less than 200ns rise and fall times.
But there're other ways to do it, without crystals.
or
Do they have any advantage?
Maybe you can change frequency more easily with a potenciometer, while the crystals only lets you some power of 2 divided frequencies. But the crystal is more accurate, isn't it?
Thank you
Yes, the crystal is FAR more accurate. The best solution though is a PLL using a crystal as the reference, so you can switch frequencies easily and accurately.
The simple oscillators have a different frequency with each IC and the frequency changes when the supply voltage changes.
The links I posted, show 2 approaches with IC that do not depend on supply voltage, only R and C.
Yes, PLL is good, but seem much more complex.
No.
The links (performance) show a big change in frequency when the supply voltage is changed.
The datasheets for the ICs show that each one is very different (threshold voltage) which affects the frequency.
