Problem in Interfacing Battery with Reed switch-Help me please.
sreekanthm
Dear all,
I have designed a battery(Lithium-Ion, 5.2 Amp/Hr) operated instrument. Instrument when switched on takes 1.5 amp of current.
I have conneted a reed switch(RI-25C,coto technology) having switching current capacity of 1 Amp and continuous carry current capacity of 3 Amp in series to battery.
Reed switch closes when a magnet is brought near to it and opens when the magnet is taken away.
Problem is when i interface the reed swith with the battery and bring the magnet near to it ,it closes and the instrument is powered,but when i bring the magnet away from the reed switch it still remains in closed state only and does not open.
If any one have the experiance in using reed switch or have an idea to solve the problem please let me know.
Thanks & Regards,
Sreekanth Reddy.M
The reed switch has a MAXIMUM switching capacity of 1 amp, and you are switching 1.5 amps that probably has a big capacitor too?
Sounds like you are exceeding the capacity of the reed switch, and possibly destroyed it. I would not run one anywhere near it's max switching capacity as a general rule. Maybe you could use the reed switch to operate a FET or transistor which switches your load current?
Sorry MR RB , It is 0.5 amp of switching current i have written it as 1.5 amp.
Thanks MR RB ,I am very Sorry its my mistake.Instead of writing the switching current of instrument as 0.5 map i have written it as 1.5 amp.
Please suggest me the solution.
Thanks and Regards,
Sreekanth
Thanks and Regards,
Sreekanth
It's still probably a faulty switch, either replace it or take it apart and clean the contacts.
Reed switches do not like taking much current. They weld shut if there is a current surge.
Use the reed switch to turn on a relay or an FET.
