Oznog
Active Member
I am now trying to figure out how to measure airspeed with pitot tubes, which measure a pressure difference between a closed tube facing towards the direction of travel and static air.
The pressure differences are quite small, under 1 psi. 30 mph equals 0.03 psi difference.
I need a differential (gauge) pressure sensor, and I'd like one with two hose barbs. Some (most) just have a vent in back, but I need to take it to a static source elsewhere so I need a second barb.
The problem is the sensors I've looked up have rather crummy offset to signal ratios. There's a common, economical 1.45 psi diff sensor which reads 12.5 mV diff output fullscale with a 5V supply, but there's an offset error of 0.5 mV, or 4%, in it. I believe this would be a problem since this correlates to around 60 mph.
If the offset is extremely consistent I'd have no trouble zeroing it, but I don't know how consistent that is. I'd hope to be within 2.5 mph here, preferrably less still. It's going to see lots of temperature and ambient pressure variations too. It just looks like I'm using far too little of the scale for this device and the offset is going to blow it completely.
Anybody got a better idea for sensing pressure? I'm still pretty set on sensing airspeed by pressure diff, but I need a more promising solution.
