Nokia Headphone Upgrade
v1.5
Hi i have a nokia 6610 phone which is very old one and i want to repaire and uprade it for some reasons.
The problem is about the headphone of it. Its hard to find official headphone so i have though that i may can change it with modern headphones by soldering directly to the circuit board .
On the link page you can see pop-port pinout of nokia ;
The table says that each headphone parts (right-left-mic) has its own positive/negative terminals. But on the modern headphones just have positive terminals of them and common ground. I have thought to solder a modern headphone to the exact pinout of the nokia's positive terminals except shorting all negative terminals of right-left-mic parts of each others and connect them to gnd. But im not sure if it will work or not .
What do you think ?
MacIntoshCZ
Active Member
So speaker is not working and you want to solder headphones directly to speaker input pins?
v1.5
actually speaker working but i want to make phone calls using headphone for more comfortable usage. Like modern headphone attached phones.
MacIntoshCZ
Active Member
So yours phone doesnt have 3,5mm jack and you want substitute that? What about reduction?
v1.5
I would go for reduction. Soldering headphones to board could be hard
So if i can handle this will that work ? What do you think ?
MacIntoshCZ
Active Member
It should work. Reduction does same thing. But do not short anything. Just try GND and one of the channels
